Leaning to left on SOA and SF.. - Page 2 - JeepForum.com
post #16 of 23 Old 04-02-2013, 08:15 AM
revelc
1985 FSJ Wagoneer
Originally Posted by olliehopnoodle
Make sure they are setup for SOA. The second spring needs to be longer, almost all the way to the mounts.
Not many companies make them that way. I think one makes "military wrap" style springs for FSJ's. The second spring wraps around the first ones eyelets in case it breaks.
Although they are nice, they are not a must. Not everyone wheels hard enough to break them.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #17 of 23 Old 04-02-2013, 08:33 AM Thread Starter
mtuck83
The add a leafs are from rustys... This isn't gonna b a hardcore wheeler by no means. I'm not at the house this morning to do the measuring. But it doesn't make sense to me why it still sits un level. I've got everything correct according to the instructions. Could the springs just be wore out that much? And as far as the body bushings, there all dry rotted but not too bad. Pretty equal all the way around. Once I get off work this evening ill measure and post what I find out. Until then keep the recommendation coming!!
mtuck83 is offline
post #18 of 23 Old 04-02-2013, 11:45 AM Thread Starter
mtuck83
After measuring from the axle to the frame on each corner, these are the numbers I come up with.
Left front 12 3/4
Right front 13 3/4
Left rear 15
Right rear 15 3/4
Doesn't sound like much but it definitely has a lean.. And when I get it of course it's way worse. I DO NOT have shocks mounted right now but this shouldn't make that much of a difference should it? When I sit in the passenger side it looks a ton better...
mtuck83 is offline
post #19 of 23 Old 04-02-2013, 12:20 PM
RockRollin
1990 FSJ Wagoneer
Is that about the same as before you swapped sides with the springs.
I loosen all shackle bolts a bit, maybe you have one binding.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #20 of 23 Old 04-02-2013, 12:35 PM Thread Starter
mtuck83
I didn't measure it but appearance wise it seems to be the same if not worse...
mtuck83 is offline
post #21 of 23 Old 04-02-2013, 03:28 PM
RockRollin
1990 FSJ Wagoneer
Shocks shouldn't make a difference. If your confident in the geometry of the modification, nothing as far as shackles or spring mounts are over torqued and binding. Well, how was it's stance before sf/soa (I'm assuming same springs). Eliminate the possibilities till your down to new springs.
Ya didn't forget to move a jack stand did ya jk
"I like fun" Edd
post #22 of 23 Old 04-02-2013, 04:28 PM Thread Starter
mtuck83
Seems like it had a little lean but nothing like now...and I wish the problem was just a jack stand, removing that is a lot cheaper than springs. Lol
mtuck83 is offline
post #23 of 23 Old 04-02-2013, 06:52 PM
super98lsc
disconnect the track bars and see what happens. My 90 has front and rear t bars and it causes a left lean unless you lengthened them or customized brackets for it.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
