leaf spring rubbing frame rail - JeepForum.com
post #1 of 12 Old 04-23-2013, 03:56 PM Thread Starter
cookingguy
1979 FSJ Cherokee
So the drivers side rear leaf pack and the U bolts are rubbing the frame. What could be the cause of this? How bad is this problem?
cookingguy is offline
post #2 of 12 Old 04-23-2013, 04:02 PM
olliehopnoodle
1982 FSJ Cherokee
pics would help
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #3 of 12 Old 04-23-2013, 04:10 PM Thread Starter
cookingguy
1979 FSJ Cherokee
will get some pics up soon
post #4 of 12 Old 04-23-2013, 04:32 PM Thread Starter
cookingguy
1979 FSJ Cherokee
here are a couple pics
post #5 of 12 Old 04-23-2013, 04:36 PM
CSP
Those pictures are itty bitty and don't get larger if you click on them.
Have you inspected the shackle area (I think that's the shackle at the left side of pic #2) to see if everything is aligned correctly there?
CSP is offline
post #6 of 12 Old 04-23-2013, 04:56 PM Thread Starter
cookingguy
1979 FSJ Cherokee
what would I be looking for to see if everything is aligned correctly?
post #7 of 12 Old 04-24-2013, 12:09 AM
Dngrs1
1979 CJ7
Did you put the springs on upside down?
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #8 of 12 Old 04-24-2013, 09:16 AM Thread Starter
cookingguy
1979 FSJ Cherokee
I did not install the springs
post #9 of 12 Old 04-24-2013, 10:19 AM
CSP
Look for obvious things like broken parts or missing bushings. Check that the hardware (bolts) is tight. No internet guesswork is going to take the place of actually looking at it first.
CSP is offline
post #10 of 12 Old 04-24-2013, 03:48 PM
RockRollin
1990 FSJ Wagoneer
Is that the same side you had pulled apart for the bent bolt?
Also , how much clearance do you have on the other side.
Pics from the rear down both sides
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #11 of 12 Old 04-27-2013, 08:58 PM Thread Starter
cookingguy
1979 FSJ Cherokee
It is not the side I pulled apart for the bolt I will get more pics and clearance numbers tomorrow
post #12 of 12 Old 04-28-2013, 09:24 PM
CSP
So what do you see that's different from the side that doesn't rub? There should be clues when comparing the two sides.
CSP is offline
