Jeep Th400 - JeepForum.com
post #1 of 8 Old 12-08-2011, 05:34 PM Thread Starter
k10silverado
1977 FSJ Cherokee
Jeep Th400
Hey guys, i have a 1977 jeep cherokee and it is epuiped with a jeep th400.
Im aware of the jeep th400 has a 10 spline tail shaft. im wanting to upgrade from the quadratrac transfer case to a NP 205. Ive been told i would have to change out the tail shaft to do so because of the 10 spline shaft. But the np 205 that was mated to the gm 4 speeds has a 10 spline input. My question to you guys is will it work or can i make it work? Or is there another solution to get a np 205 behind my th400? Any help is appreciated!!! thanks guys
k10silverado is offline
post #2 of 8 Old 12-09-2011, 09:30 AM
CSP
The tailhousing is different and I suspect the length of the output is also different.
CSP is offline
post #3 of 8 Old 12-09-2011, 06:03 PM Thread Starter
k10silverado
1977 FSJ Cherokee
thanks, do you know if they make a adapter for this setup. Ive searched but i haven't found one.
post #4 of 8 Old 12-10-2011, 06:08 AM
sgtdave
1974 CJ5
adapter
Advance adapter makes a kit to change over to a Dana 300/231/ 205/203 transfer case. The kit gives you a new output shaft 23/27 depending on what T case you want. They are all over $500.00 so it will be pricey.
I went with a TF727/D300 combo it was $350 with the T case this may be a better option for you The TF727 is a very strong trans being used behind most of the Mopar big blocks in the muscle car days. Just some food for thought.
Dave
sgtdave is offline
post #5 of 8 Old 12-10-2011, 08:42 AM
BJ's Off-Road
1979 FSJ Cherokee
Dave
Just for a note, if you have a 1980-1991 FSJ TF727, a Dana 300 will bolt up with no adapter.
Also, the TH400 was used behind GM big blocks as well. The TH400 and TF727 are very equal in strength, they will hold up to a lot of abuse.
www.bjsoffroad.com
BJ's Off-Road is offline
post #6 of 8 Old 12-10-2011, 05:27 PM Thread Starter
k10silverado
1977 FSJ Cherokee
Thanks for that helpful information. Im going to give it some thought.
post #7 of 8 Old 12-13-2011, 02:51 AM
carnuck
1984 J-Series Truck
You won't need an adapter if you get a Chev TH400 with the right case already on it. (I see them for less than $200 on CL) Rebuild your old trans and put the Chev parts on the AMC case (or find one that needs rebuilding)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #8 of 8 Old 12-18-2011, 04:09 PM
Dngrs1
1979 CJ7
Why not just install a part time kit into the QT?
Dngrs1 is offline
Rebuilt 401 + TH400 Obi-Wan Full Size Jeep Forum 3 07-30-2010 08:26 AM
th400 flilled 6 qts, not nothing Eric1080 Full Size Jeep Forum 8 03-16-2010 04:24 PM
th400 to chevy 208 79cherokee4x4 Full Size Jeep Forum 7 01-22-2010 11:39 PM
swap internals from amc th400 to sbc th400 Phoenix916 Full Size Jeep Forum 1 08-06-2009 02:02 PM
th400 Q's McWood Full Size Jeep Forum 2 04-25-2009 09:22 PM
