Jeep t18 - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Jeep t18
LOCKERS!!!! - ARB, Auburn, Detroit, Eaton, OX, Spartan, YuRIGID LED Light Blowout Sale - All Sizes, All Series, all ECGS Black Friday Sale!!
Unread 11-14-2014, 02:32 PM   #1
Jordan2534
Jeep t18
I have t18 out of a 74 j10, I'm wondering the difference between te ford t18 and jeep. Mainly strength. I don't mind buying an adapter, but I want to run it behind a 7.3 idi
Jordan2534 is offline   Reply With Quote Quick reply to this message
Unread 11-14-2014, 04:10 PM   #2
CSP
Internals are the same. The bolt pattern is different where it attaches to the bellhousing and the fullsize Jeep T18s have much longer input shafts than Ford.
CSP is offline   Reply With Quote Quick reply to this message
Unread 11-14-2014, 05:36 PM   #3
Jordan2534
So I will need an adapter from Novak or someone similar. Did the ford t18 ever come behind a 7.3? Is that a trans anyone would use?
Unread 11-15-2014, 11:15 AM   #4
Jordan2534
Another option... This one would probably be best. I have another j10 amc 360, dodge 727, unknown t case. The t18 from the 74, will bolt up to the amc 360 and the unknown t case should bolt up to the t18
An then look for a ford t18 or a zf5 for the 7.3. Probably easiest and cheapest way to do it, I do want both to be manual transmission, and then I don't need to run adapters or anything
Unread 11-15-2014, 11:26 AM   #5
CSP
I'm not sure where you assume what will bolt up, but it's incorrect. The "unknown" tcase will be a drivers drop New Process case and it will not bolt up to the T18. Just because it all came out of various Jeeps doesn't make it all compatible.
A Jeep T18 will not bolt up to any Ford engine using a Ford bellhousing. The input shafts are too long. You'd have to swap in a Ford input shaft for it to work.
Any Ford 6.9 or 7.3 with a four speed, the transmission will either be a T18 (most likely) or a T19. The 6.9 and 7.3 have the same bellhousing pattern, so it doesn't matter which engine it is.
Unread 11-15-2014, 11:54 AM   #6
Jordan2534
Originally Posted by CSP
I'm not sure where you assume what will bolt up, but it's incorrect. The "unknown" tcase will be a drivers drop New Process case and it will not bolt up to the T18. Just because it all came out of various Jeeps doesn't make it all compatible. A Jeep T18 will not bolt up to any Ford engine using a Ford bellhousing. The input shafts are too long. You'd have to swap in a Ford input shaft for it to work. Any Ford 6.9 or 7.3 with a four speed, the transmission will either be a T18 (most likely) or a T19. The 6.9 and 7.3 have the same bellhousing pattern, so it doesn't matter which engine it is.
Hey. Thanks a lot for the info. Will the t18 bolt up to an amc 360? Because I do have a passenger side t case attached to the t18. As well as passenger side drop dana 44
Unread 11-15-2014, 02:28 PM   #7
CSP
If it came off another AMC engine it will. You'll need a 360 specific flywheel as the AMC V8s are externally balanced and the flywheels are specific to each engine's displacement.
There are different T18s for fullsize Jeeps though. The input shaft on the V8 version is much longer than the straight six version.
Unread 11-15-2014, 10:44 PM   #8
Jordan2534
So because of the shorter input shaft is the straight six version not useable behind the v8. Thanks for helping me here
