Jeep keeping cool - JeepForum.com
post #1 of 9 Old 06-21-2013, 10:42 PM Thread Starter
89shaggoneer
Jeep keeping cool
Hey guys so I currently have a 1989 jeep grand wagoner, with aftermarket aluminum radiator but no fan shroud. The fan clutch etc and thermostat is in good working order, The jeep keeps cool under normal driving operation it gets a little warm on long idles in hot weather but stays fairly good, but on low rpm/ idling offroad etc the jeep gets way to hot, also im getting the ac system operational and was told without a fan shroud or something pushing more air through it would build up too much back pressure?! soo my question is should I spend the 150 plus dollars to have a fan shroud built im unsure that a stock/junkyard fan shroud would fit on my aftermarket radiator, or would say a heavier dutier hayden fan clutch pull enough air through? for the ac to work well even at idle? Any thoughts opinions or ideas are greatly appreciated also ive looked and there really is no room for a electric pusher fan either. Thanks guys
89shaggoneer is offline
post #2 of 9 Old 06-22-2013, 10:15 AM
super98lsc
swap in an electric fan from a Taurus. For the AC and low speed crawling it will be awesome for you. The AC condenser needs a lot of airflow to pull the heat and in turn pressure off the Freon after its compressed ie exiting the high side of the compressor. Without adequate air flow the head pressures will remain too high at low speeds and the air won't be as cold as it should. This is especially important with r134a as it works the compressor and condensing unit harder than r12 did. Mine blow 37-42 at the register on the road and 45 at idle. When I had the engine fan, new clutch and yes a complete factory shroud it would blow 58-63 at idle.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #3 of 9 Old 06-22-2013, 11:01 AM
olliehopnoodle
1982 FSJ Cherokee
What aluminum radiator do you have. I have a be cool and was able to modify the stock shroud to it pretty easy.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #4 of 9 Old 06-22-2013, 03:10 PM Thread Starter
89shaggoneer
I have no idea what aluminum radiator it is its certainly heavy duty it came with it when I bought it, Also super98lsc are you running just a ford Taurus electric fan without regular fan? and that keeps you cool at idle?
post #5 of 9 Old 06-23-2013, 09:11 AM
super98lsc
Yes Taurus 2 speed fan and it keeps cool on low speed. above 35mph or so the fan never even comes on unless I am using the AC. Fan is always on with AC in all cars.
post #6 of 9 Old 06-23-2013, 02:55 PM Thread Starter
89shaggoneer
Anyone have any experience with a hayden 2747 fan clutch and 6 blade fan? for pulling enough air for ac... really trying to stay away from having to build a fan shroud?
post #7 of 9 Old 06-24-2013, 06:35 PM
olliehopnoodle
1982 FSJ Cherokee
A mechanical fan won't do you much good without a shroud. Take a couple of pictures of your radiator and post them. I modified my shroud to work with both a BJ's and a BeCool. It took a little patience but was effective. I know other folks that have built a simple shroud. Without a shroud your fan is going to mostly just move air around inside the engine compartment.
post #8 of 9 Old 06-24-2013, 07:21 PM Thread Starter
89shaggoneer
Thankyou I installed the hayden clutch and it dramatically moves more air but yes a shroud is still necessary, Located a guy with a bunch of fsj's hes parting out says he has one picking it up for 50 bucks not bad since a replacement is 185 shipped. Hopefully ill have the jeep nice and cool asap!!
post #9 of 9 Old 06-24-2013, 09:06 PM
olliehopnoodle
1982 FSJ Cherokee
Cool. A dremel is your friend as you attempt to modify the shroud. If I remember its the trans lines and even the hose locations that had to be trimmed. Also pay attention to the mount ing holes. Make sure there is clearance for the top of the fan.
