Jeep/Grand Wagoneer mechanic/electrical in Chicago? - JeepForum.com
post #1 of 8 Old 03-30-2013, 11:53 PM Thread Starter
ScottGoChicago
I'm looking for a shop/mechanic to take my 87 GW to and have the wiring cleaned up. My near term issue is I don't have tail lights (do have break lights) or dashboard lights.
Any help or recommendations appreciated.
You can reach me at scott.golas@gmail.com
ScottGoChicago is offline
post #2 of 8 Old 03-31-2013, 07:44 AM
revelc
1985 FSJ Wagoneer
Have you tried changing the bulbs tail light bulbs? They can be burned out.
And try turning your headlight switch side to side with the lights on? Mine started working after I did that for a little while.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #3 of 8 Old 03-31-2013, 08:55 AM
Dave145
1976 FSJ Cherokee
Did you check your fuses?
Dave145 is offline
post #4 of 8 Old 03-31-2013, 09:13 AM
Saul32
1988 FSJ Wagoneer
Corral auto 2300 S Kedzie. Fidel is his name and all the mechanics that work for him are great. My GW is there now getting a bit of work done
Nothing important...
Saul32 is offline
post #5 of 8 Old 04-01-2013, 11:05 AM Thread Starter
ScottGoChicago
I hadn't checked bulbs, seemed odd that they would both go out simultaneously and I'd have break lights?
I did check fuses under dash (to left of steering column). That said I was never able to specifically identify the fuse that handled such.
Read recently something about checking "the fusible links at the starter solenoid" as possibly having an impact on lights?
scott
post #6 of 8 Old 04-01-2013, 12:34 PM
revelc
1985 FSJ Wagoneer
scott
Not at all. Happens more often than you think. ( lights burning out at same time)
If you can't figure out which fuse is which make sure they are all good and replace and burnt ones.
revelc is offline
post #7 of 8 Old 04-02-2013, 01:18 PM Thread Starter
ScottGoChicago
Might as well ask since I dont have immediate access to GW, is it easy to check/change tail light bulbs on 87 GW, or are the hard to reach?
post #8 of 8 Old 04-02-2013, 05:37 PM
revelc
1985 FSJ Wagoneer
Two Phillips head screws. Lens comes off. There they are.
revelc is offline
