J10 wont start - JeepForum.com
post #1 of 17 Old 09-24-2011, 06:29 PM Thread Starter
240impala
2003 WJ
J10 wont start
Ok I got 79 jeep j10 4.2l won't start I can put starter fluid in it and it busts off and then runs perfect. I have replaced the filter plugs wires cap rotor fuel lines. Any ideas
"Don't Do It"
IRO 6.5" lift, IRO Front long arms, rear iro adj upper a arm and adj rear lower, custom 4x4 fab front bumper, rough country winch, 15" crager soft 8's, procomp 35-12.50 tire, fenders trimmed KOR light bar, malone roof rack
240impala is offline
post #2 of 17 Old 09-24-2011, 07:12 PM
pleontks
1976 J-Series Truck
fuel pump
Beauty is in the eye of the jeepowner.
pleontks is offline
post #3 of 17 Old 09-24-2011, 07:24 PM Thread Starter
240impala
2003 WJ
It's pumping fuel out the filter pretty good but could be weak
"Don't Do It"
post #4 of 17 Old 09-24-2011, 08:56 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Carb is dirty/clogged?
Obviously it's getting air in, and its getting fuel to the carb, but something between the fuel inlet on the carb, and the intake is amiss.
Sounds like a carb problemo to me, sir.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #5 of 17 Old 09-24-2011, 09:09 PM Thread Starter
240impala
2003 WJ
Yeah I have cleaned the line and that needle on the inlet. I just dont get how when it busts off it runs fine no problems.
"Don't Do It"
post #6 of 17 Old 09-24-2011, 09:26 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
what do you mean busts off?
You can get it started with starting fluid, and it runs fine, but when you try to start it without it, it doesnt work?
Hmm.
-Andrew
Marn is offline
post #7 of 17 Old 09-24-2011, 09:50 PM Thread Starter
240impala
2003 WJ
Hmm.
The motor starts?
Yeah runs great when I spray it idles great can run it forever but cut it off and just turns over till I spray it again
"Don't Do It"
post #8 of 17 Old 09-25-2011, 01:26 AM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Okay, tell me if these situations are correct.
1. Turn the key, it just cranks and cranks. doesnt start.
2. spray starting fluid in the carb, crank, it starts, stop spraying fluid, it keeps running like a normal vehicle. ( the only issue is getting it started, then it runs normal)
Or are you saying that you have to keep spraying starting fluid to keep it running?
If it ONLY runs while you are spraying, then there is an issue somewhere in the carb. Breather holes can be clogged, small lines can be clogged. You'd probably eb looking at a full rebuild, and in doing so I would soak it in carb cleaner or lacquer thinner or something over night, to clean out all the small passages.
-Andrew
Marn is offline
post #9 of 17 Old 09-25-2011, 08:00 PM Thread Starter
240impala
2003 WJ
Ok may know what's wrong does anyone know the type of carb this is 79 4.2 stock carb.
"Don't Do It"
post #10 of 17 Old 10-28-2011, 12:01 PM
carnuck
1984 J-Series Truck
Sounds like the choke isn't working
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #11 of 17 Old 10-28-2011, 07:21 PM Thread Starter
240impala
2003 WJ
No it was the float and now the motor is out :/
"Don't Do It"
post #12 of 17 Old 11-18-2011, 10:27 PM
carnuck
1984 J-Series Truck
Because of the valves? 1 bbl carb or 2 bbl? I have the 2bbl BBD Carter and separated intake/exhaust from my '83 J10's 258 on Ebay right now (shipping sucks due to weight)
FOR SALE STUFF
carnuck is offline
post #13 of 17 Old 11-19-2011, 05:18 AM Thread Starter
240impala
2003 WJ
I don't need a carb the motor is out. I'm rebuilding it and putting a weber or a 4 barrel on there. Do you have any other parts for sale?
"Don't Do It"
post #14 of 17 Old 11-22-2011, 07:33 PM
carnuck
1984 J-Series Truck
I don't understand why you pulled the motor because the carb was bad?
FOR SALE STUFF
carnuck is offline
post #15 of 17 Old 11-22-2011, 11:31 PM Thread Starter
240impala
2003 WJ
No because a valve was sticking. And when I pulled the head the motor was full of gunk so I pulled and am freshening it up. As well as getting rid of that junk carter carb and putting a weber on there with an hei distributer
"Don't Do It"
