Quantcast J10 Series FSJ - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > J10 Series FSJ
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 08-10-2004, 07:20 AM   #1
mwassi
J10 Series FSJ
Looking into buying a full size J10 truck....what is the best year to buy?
mwassi is offline   Reply With Quote
Old 08-11-2004, 10:28 AM   #2
jode
Well, that is a loaded question. I prefer a 78-79 since that was the year that the frame changed a bit (added bumper mounts) and the ignition was upgraded (from Prestolite to Duraspark). But both of those are pretty small reasons. A little welding and the frame issue goes away, and the ignition is easily swappable from the pre-78 to post-78. However, once you get into the 80s, they removed the "visor" from the top of the cab and from then on, the J trucks just don't have "the look" IMHO. Jtrucks earlier than 74 were not branded J10 or J20, (they were J200, 300, 4000, etc.) and they came with a hard-to-lift post-mount spring mounting system, questionable wiring, and closed knuckle front ends. Again, with some ingenuity, all of those differences are overcome by a man with a welder and some tools (and time/$$). The main thing to look out for is (IMHO) rust/cancer under the floor boards and on the cab corners. If you have any more questions on any of the things mentioned above, try the search function at www.ifsja.org
jode is offline   Reply With Quote
Glock Forum
