j10 low gear problem/question - JeepForum.com
post #1 of 5 Old 04-04-2010, 11:42 PM Thread Starter
ajf
1984 J-Series Truck
hey guys i just picked up my first jeep and first 4x4 last week and after fooling around with it have a question or two...
1. what is the proper procedure for putting the jeep into 4x4?
and
2. what is the proper procedure for putting it into low?
i have put it in low but when i do the rear tires seam to skip along and dont turn smoothly sooo anyone know what the problem is or experience this before? any advice or assistance is very well apreciated, thanks for the help and sorry for elementry questions
ajf is offline
post #2 of 5 Old 04-05-2010, 12:16 AM
Angry_bald_guy
1985 J-Series Truck
Sounds like you might have different gear ratios in the front and the back. VERY BAD FOR THE TRANSFER CASE!!! Check on that ASAP!
Darrel
A well regulated militia being necessary to the security of the free State, the right of the People to keep and bear arms shall not be infringed.
JFI Member #13
Angry_bald_guy is offline
post #3 of 5 Old 04-05-2010, 08:44 AM
CSP
If you're using 4wd on dry pavement the trouble turning and skipping would be normal.
You're not supposed to have it in 4WD on hard, dry surfaces.
CSP is offline
post #4 of 5 Old 04-05-2010, 09:51 AM Thread Starter
ajf
1984 J-Series Truck
ok well to clarify the 4wd isnt the issue that seams to work but the low gear is when it skipps when in 2 low or 4 low
also can anyone tell me the correct procedures for putting in 4wd and low?
ajf is offline
post #5 of 5 Old 04-05-2010, 11:28 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
If you have tires dragging in 2wd, then you need to open your rear diff to see if you have a locker, spool, or perhaps a welded carrier in there.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
Any Virginia boys in here? Gear ratio question. DuckBox Full Size Jeep Forum 5 03-16-2010 10:12 AM
J20 steering gear ChicagoYJ Full Size Jeep Forum 5 08-13-2009 08:27 PM
Gear grinding going from Hi to Lo stonehengeheels Full Size Jeep Forum 4 01-29-2009 08:30 AM
cant get 4x4 into gear, HELP FAST j20monster Full Size Jeep Forum 1 01-28-2009 06:49 AM
gear question Muddy Tj Zack Full Size Jeep Forum 1 10-06-2005 12:10 PM
