#1 | |
J-series info...
This is just a general feeler thread. I am considering a buildup of a J-series truck some time in the (distant) future. I love jeeps and I've always wanted a pickup so I decided to turn it into an excuse to do a build.
![]() After doing a bit of searching there really isn't a lot of info on the j-series trucks out there (at least not that I could find) so I thought I would pick the brains of you pickup guys and see if you can steer me in the proper direction. Still not sure how exactly I want to build this up (only been batting the idea around for a few weeks) but I do know I want to be able to drive it both on and off road. Any wheeling will probably be light, so i'm thinking 33-35's. Axles and motor will depend on what I end up getting stock. So, I suppose what i'm looking for is which models should I keep an eye out for and which ones should I avoid. Also any sites or online resources would be awesome. Thanks!
#2 |
ifsja.org go to the tech library and the message forums you wont find more informaton anywhere, gauranteed.
these trucks make very cool wheeler/on road drivers. 33-35 inch tires require only a lift kit and a few other small parts, no major modifications. 33s fit with 4 inches of lift, 35s with 6 inches. you want to be looking for trucks 76-88 because the frame was altered for 76 and MOST lift kits cover these years, and FEW cover the rest. Also after 74 the trucks have a lot of standard features that are desirable (PS PB disc front brakes open knuckles etc etc). After that its up to you which drivetrain you want. 76-79 they used the th400 and quadratrac and 80-88 they used the tf727 and np208 (for the most part). If you go manual you are looking at the t-18 and d20 or the t-176 and np208, respectively. the 258 was standard every year but it seems to me the 360 got special ordered A LOT and the 401 is rare and extremely desirable. axles were passenger side drop 76-79, drivers side 80-88... dana 44 every year. offset rear 44 for the QT and centered amc20 for the NPs. The model20 in the full size trucks were upgraded versions of the CJ ones and are arguably as strong or slightly stronger than a 44. |
#3 |
I think I cornered the market on the J trucks here in Seattle (I own just about 1/2 them probably) The TH400 was the auto used from start to FSJ production (except with the 232 and 230 6 cyls which got Borg Warner unless someone found one with an adapter ring?) D20 was used til '73 (when Quadratrac came out)
#4 |
Hey,
Welcome to the club, man. I just got a '77 Honcho out here in NW Arkansas. It's running nicely, but there's a lot of work/mods to be done with it. It's just about impossible to find decent info online. I'll try to keep you in mind as I build up mine. So far, I know the interiors of the J-series are pretty interchangeable with G Wagoneers. I also know that the AMC 360 is definitely the best choice for any J-10. Mine isn't a step-side, but who says it can't be one in the future? grin... Best of luck.
[FONT="Garamond"][COLOR="Green"]-Wes de la Ozarks[/COLOR][/FONT] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
