Intermittent transmission problems - JeepForum.com
post #1 of 4 Old 04-02-2013, 05:09 AM Thread Starter
Little Green
1991 FSJ Wagoneer
Hey crew,
Sometimes within 5-10 minutes of starting the waggy I come to a complete stop(stoplight, stop sign etc) and the truck will not go forward. Sometimes if you give it gas it will suddenly "catch" and go or you slide it back to neutral and back to drive and it goes no problem. Sometimes it does not do it at all or does it once and no more problems or it will do it 2 or three times. It seems like after about 10 minutes or so I don't tend to have issues.
It does not feel like it's slipping at all. Just give it gas and nothing, like it's not in gear. Any ideas?
91 Grand Wagoneer(Winter vehicle/project)
Prior 08 Wrangler JK Lifted-Miss her
Little Green is offline
post #2 of 4 Old 04-02-2013, 05:16 AM
RockRollin
1990 FSJ Wagoneer
If fluid level is right, then I would go after filter change.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #3 of 4 Old 04-02-2013, 08:38 AM
olliehopnoodle
1982 FSJ Cherokee
Yep, what he said. And soon.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #4 of 4 Old 04-02-2013, 11:03 AM
super98lsc
Drop pan drain fluid, rinse down the valve body with brake cleaner and replace the filter. Honestly this sounds like worn seals internally which is causing the rear clutch to not have enough pressure to stay engaged from an idle. Check the trans cooler lines, hoses, and flush out the cooler as well. Any restriction there can also cause this. Does it do the same thing in manual 1 ? If it does not do this in manual 1 then likely the overrun clutch which is used to holds the low reverse drum stationary when in Drive mode. Placing the lever in Manual 1 forces the Low/Reverse band to engage and hold the drum so if the overrun clutch isnt holding the problem will go away when placed in Manual 1. If it does this in both modes Drive/Man 1 then likely the rear clutch is worn or not receiving enough pressure to hold proper engagement at idle. Front pump could be worn, general worn seals in the trans etc. Providing the pump is coming up to pressure the trans may last a while longer if your easy on the go pedal. This is of course assuming were speaking 727 here.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
