Interior and Division Bars-Window seals - JeepForum.com
post #1 of 3 Old 07-05-2013, 10:03 AM Thread Starter
super98lsc
1. So decided to fix the rust and some actual holes in the roof gutters over the passenger doors. Found one spot that was bad enough that the air was blowing right in through the outer door jamb into the A-Pillar on the windshield. Truck is really rust free other than these few spots where the PO didnt prep properly before the repaint. Not a drop of rust on the rockers or floor pans. Ugh... welded, filled, zinc coated, etch primed and painted.
2. Removed the passenger door glass and regulator to replace the division bar seals and window channel felts etc. Parts from BJ"s are nice and perfect fit the only PITA with this job is the damned rivets. I am going rivet hunting again here shortly to try and find some with long enough stems to pass through the "rivet spacer tool" and still grab the jaws inside my gun.
3. Repainted the upper metal door panel trim/retainer strips. Man these things were all chipped, scratched and rusty making the truck look run down and old. Amazing how much nicer she looks now.
and of course i tried to upload pix but alas the forum wants them in 1x1 DPI. I re-sized them twice might be easier just to send you guys some macaroni pictures.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #2 of 3 Old 07-08-2013, 12:41 PM Thread Starter
super98lsc
Ok finally had time to download an app and res the pix way down.
post #3 of 3 Old 07-08-2013, 12:48 PM Thread Starter
super98lsc
more, man the rust was ugly, i ground it out welded, zinc coated, acid primed, filled it then painted it over with some base white for now.
