Instrument lights not working - JeepForum.com
post #1 of 6 Old 05-22-2013, 06:56 PM Thread Starter
Chrisv102581
1979 J-Series Truck
My instrument lights (all except turn signal indicators) aren't working. I switched out all the bulbs and nothing. Where should I start?
Chrisv102581 is offline
post #2 of 6 Old 05-24-2013, 09:32 AM
Dale1966
1980 FSJ Wagoneer
Chris, have you checked all fuses ?
Dale1966 is offline
post #3 of 6 Old 05-24-2013, 01:12 PM
Dngrs1
1979 CJ7
Make sure there is a good ground to the instrument cluster board.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #4 of 6 Old 05-24-2013, 08:03 PM
79chiefs
1988 XJ Cherokee
Mine too, i tried to clean contacts, i think it could be headlight switch on mine. Not sure,
Sub'ed
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #5 of 6 Old 05-25-2013, 01:28 PM
bcrawler
1981 FSJ Cherokee
Mine did the same thing.Try running a wire from the speedo screws on the back to ground and test the lights. Mine lost ground and this is the repair I did to fix.
bcrawler is offline
post #6 of 6 Old 05-25-2013, 03:58 PM
revelc
1985 FSJ Wagoneer
Mine worked after I rotated my headlight switch back and forth a few times.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
