Install new timing chain questions - JeepForum.com
post #1 of 4 Old 07-08-2013, 07:42 PM Thread Starter
chris64
1979 FSJ Cherokee
Ok, here's the update.
Found a really nice block 10 minutes from my job! block is getting bored for the new pistons. Any advice on installing cam gear? I know the gears have to be indexed. Not like a sbc that you can bolt on. I am stoked to think next week I will be assembling new motor!
Thank you, C
chris64 is offline
post #2 of 4 Old 07-08-2013, 08:40 PM
RockRollin
1990 FSJ Wagoneer
Check the centerline on the cam that you are using. From the factory the cam was retarded. Many after market performance cams do not follow the factory center. I don't know how familiar you are with the effects of degreeing a cam, but a google search will give you volumes of info.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #3 of 4 Old 07-09-2013, 05:53 AM Thread Starter
chris64
1979 FSJ Cherokee
Thank you, but I am asking how to install the cam gear
chris64 is offline
post #4 of 4 Old 07-09-2013, 09:55 AM
RockRollin
1990 FSJ Wagoneer
OK
Between the title and the indexing the gear question, how did I miss that
"I like fun" Edd
