Ignition/Starter "Event" - JeepForum.com
post #1 of 8 Old 01-24-2013, 07:28 AM Thread Starter
1987GW
1987 FSJ Wagoneer
Hi all,
Just went out to start the 87 GW, and had an event that I haven't experienced before. Turned the key, engine turns over, release the key, starter stays engaged/spinning, entirely remove key, starter still engaged/spinning. Reinsert key to start, pump gas, engine turns over/starts, starter still engaged/spinning. Engine stalls, starter spinning/grinding (ack sounds like metal bolts in a blender), turn key again while pumping gas, engine starts, starter disengages (finally) and runs normally. Turn off engine, re-start, no issues. Drive around the block, turn off - restart, no issues. The truck sat for over a week and we've had an uncharachertistic cold spell, but I'm thinking it's a solenoid issue? Appreciate your thoughts here. Don't want to burn out the starter or trash the flywheel.
1987GW is offline
post #2 of 8 Old 01-24-2013, 09:09 AM
RockRollin
1990 FSJ Wagoneer
X2 on solenoid
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #3 of 8 Old 01-24-2013, 09:21 AM Thread Starter
1987GW
1987 FSJ Wagoneer
Originally Posted by RockRollin View Post
X2 on solenoid
Thanks - going to order a Starter Relay as well, and do both at once just to be on the safe side!
1987GW is offline
post #4 of 8 Old 01-24-2013, 04:14 PM
pleontks
1976 J-Series Truck
agree on that. don't buy the cheap one
Beauty is in the eye of the jeepowner.
pleontks is offline
post #5 of 8 Old 01-25-2013, 01:06 PM
olliehopnoodle
1982 FSJ Cherokee
I keep a 1/2" wrench handy so when this happens I can disconnect the battery really quick.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #6 of 8 Old 01-26-2013, 01:02 PM
jogde479
1985 FSJ Wagoneer
If your solenoid doesn't fix the problem you may want to look at the ignition switch. Maybe it's sticking in start instead of switching back to run? You can actually take it out while still connected and start it with a screwdriver or something, although it could just be bad in which case that wouldn't work. It's easy to get to and cheap to replace if you're still having issues...
jogde479 is offline
post #7 of 8 Old 01-27-2013, 09:22 AM Thread Starter
1987GW
1987 FSJ Wagoneer
thanks - I'll keep that in mind!
1987GW is offline
post #8 of 8 Old 02-06-2013, 02:49 PM Thread Starter
1987GW
1987 FSJ Wagoneer
Can anybody let me know where the starter relay lives? I replaced the Solenoid - was easy to find, but I can find the relay? Went to the follow link as a source, but I can't find it in my GW. What am I not seeing??
http://oljeep.com/gw/elec/JeepWireRepairTech.pdf
1987GW is offline
