ignition - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > ignition
Count Down to KOH Sale!The Original 3/8" Ruffstuff Diff Cover!Steering and more from Ruffstuff!
Unread 05-15-2014, 11:41 PM   #1
biggerhammer10
1976 CJ10
ignition
has anyone used the pertronix kits for the stock distributor body? how did it work?, have an HEI right now, but after installing the airgap manifold, there is a decided lack of space to rotate the body for timing purposes, so would like a smaller base distributor to gain more clearance, but don't want to use the stock type ford ignition box.
biggerhammer10 is offline   Reply With Quote Quick reply to this message
Unread 05-16-2014, 09:10 AM   #2
CSP
Which stock distributor body are you referring to? Your '76 would have used the Prestolite ignition, not the Ford Duraspark found in later years.
IMO, it would be a step backwards to install a points distributor in order to use the Pertronix conversion kit. If it were mine I would use the '78-91 Duraspark distributor with a GM HEI ignition module or a Capacitive Discharge ignition module like MSD.
CSP is offline   Reply With Quote Quick reply to this message
Unread 05-17-2014, 04:43 PM   #3
biggerhammer10
1976 CJ10
hei
I currently have an HEI dizzy, but it contacts both the intake manifold and the bypass outlet on the thermostat housing, so I cannot time it properly, and it doesn't want to set all the way down in the boss, so figured I would get a pertronix kit and coil to install a smaller based dizzy for clearance.
Unread 05-19-2014, 11:11 AM   #4
rkent47
1989 FSJ Wagoneer
CSP: I have just gotten an '89 Grand. We had a few full-sized Jeeps back before my sons outgrew them, so this is really great!! I am having trouble with no spark at this point and have read a couple of posts in this forum regarding resistor wire and replacing the AMC ignition module with a "GM HEI ignition module." We have a really great "ewe-pullet" junk yard not far from me that I suspect would have what I need - cheap. But I would need to know what to pull. Can you give me an idea of what I would be looking for?
Thanks ahead of time,
Kent
rkent47 is offline   Reply With Quote Quick reply to this message
Unread 05-19-2014, 11:22 AM   #5
ChrisHager
//Mr_Untouchable
ChrisHager's Avatar
Check out this thread. I think it may prove useful to you. http://www.jeepforum.com/forum/f8/ig...jeeps-1302352/
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 05-19-2014, 11:38 AM   #6
CSP
That thread is really geared to those with the '75-77 Prestolite ignition system or the '74 and older points systems. A good chunk of it is not-applicable to what rkent47 is asking about and it's definitely not what the OP is asking about.
rkent47 I suggest to go to Google and search on "Jeep stealth HEI". You'll find links that are applicable to the '78-91 Duraspark ignition system.
Unread 05-19-2014, 11:45 AM   #7
ChrisHager
//Mr_Untouchable
ChrisHager's Avatar
Oops! My mistake!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 05-19-2014, 01:42 PM   #8
rkent47
1989 FSJ Wagoneer
Great, thanks CSP. I just read the article by "Junk Yard Genius" and it was great! I am thinking that I will be doing the HEI conversion even if my OEM module is not fried at this point.
Kent
Kent - Too much iron, too little time
