Identifying an intake manifold - JeepForum.com
post #1 of 4 Old 01-23-2011, 08:07 PM Thread Starter
megajeep
1989 FSJ Wagoneer
If I were walking through a swap meet and stumbled upon a 4 barrel aluminum intake manifold, how would I identify it to truly be for my 360?
Are there better heads for this 1989 engine from earlier years?
megajeep is offline
post #2 of 4 Old 01-24-2011, 11:37 PM
GCX2450
1989 FSJ Wagoneer
Edelbrock makes heads for them. Not sure if they're any better, but I assume they should be or what's the point?
GCX2450 is offline
post #3 of 4 Old 01-24-2011, 11:53 PM
Boodyrider
I strongly suspect that even midpriced aftermarket CNC heads will blow away any junkyard head. Be careful not to go too big and lose low lift flow, which will cost you badly on low RPM torque, in order to get slightly higher max lift flow numbers.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #4 of 4 Old 01-25-2011, 08:27 AM
CSP
The 1970-mid 71 291 (casting number) heads have a smaller combustion chamber and will bump up your compression ratio a bit.
AMC heads flow really well out of the box. A little massaging of the intake ports helps them flow better.
CSP is online now
intake manifold gasket help Kris82 Full Size Jeep Forum 1 05-12-2010 02:05 PM
Need help identifying electrical part IHC Full Size Jeep Forum 2 08-27-2009 06:00 PM
Identifying Luggage Rack chevytoughrebel Full Size Jeep Forum 0 06-14-2009 12:40 AM
intake manifold silvercert Full Size Jeep Forum 6 02-09-2009 07:31 AM
intake manifold mod dzellman Full Size Jeep Forum 0 07-18-2006 12:56 PM
