I have my eye on a 69 Wagoneer - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > I have my eye on a 69 Wagoneer
Jeep Grand Cherokee Headlight AssembliesJeep Wrangler Wheel Bearing & Hub - FrontPremium LED Lighting by VISION X, Proudly sold at ROCKRIDG
Unread 07-15-2014, 11:14 PM   #1
69Wagoneer
A buddy of mine needs some cash and his selling his 69 Wagoneer. It has been sitting for a while but runs and drives. Most of the items it needs (driver side window, interior, etc) I am not too concerned about.
The one kicker is that it has an automatic transmission that does not shift itself any longer and has to be shifted manually.
Any ideas what I might be looking at here for potential fixes and a ball park cost?
It is exactly what I am looking for as a second vehicle, I just don't want to go into it not knowing what kind of upfront cost I am looking at.
Thanks in advance. When I buy it, you will see much more of me on the forum.
69Wagoneer is offline   Reply With Quote
Unread 07-16-2014, 08:36 AM   #2
super98lsc
Most likely the vacuum modulator and it's vac line is shot or missing. The th400 needs that vac source to auto shift. Change fluid for certain, install a new modulator they are cheap at local part store then snag a length of vac line and attach it direct to manifold vac.
www.mangierisrc.com
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline   Reply With Quote
Unread 07-16-2014, 09:51 AM   #3
69Wagoneer
Thank you for your response. Cheap and easy is the type of answer I was hoping for.
Unread 07-16-2014, 02:04 PM   #4
carnuck
1984 J-Series Truck
Which motor? That year could still be a Borg Warner automatic if 6 cyl. That's what the 230 OHC motor used. (there's one close to my place.)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
http://tinyurl.com/jimsclads
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline   Reply With Quote
Unread 07-16-2014, 02:37 PM   #5
GeologyJeep
1969 FSJ Wagoneer
If it's a V8 it will probably be a Buick 350cid unless somebody has changed engines. I've had one since 1973 and I'm quite pleased with it. Once the vacuum line fell off my T400 transmission while I was driving. Too long ago to remember exactly what happened but it did cause concern. Lots of later model (AMC) body parts will fit but lots won't.
I've parted out three '68-69 Wagoneers and have a lot of interior and misc. parts. So if you get it check with me about what you might need. Mr. Ed
GeologyJeep is offline   Reply With Quote
Unread 07-16-2014, 02:49 PM   #6
dahreno
What no one has noticed or care about is that you live in California. I used to live in California also. I also had a FSJ. Smogging it may end up being your biggest problem ! Go with the seller when he smogs it before he sells it to you and see what the smog guy says. This is the making of ruining a good friendship !
dahreno is offline   Reply With Quote
Unread 07-16-2014, 11:06 PM   #7
69Wagoneer
Thanks for all the replies. To answer a few of the questions:
It has the Buick 350.
GeologyJeep, I will keep you in mind when I start seeing what it needs.
dahreno, smog won't be an issue. 74 and older is smog exempt in California. One of the selling points for me.
Unread 07-18-2014, 10:36 PM   #8
69Wagoneer
I went and got it tonight. The brakes are really soft too, but he said he had them completely re-done so I need to check that out too. I am fully expecting this to be an ongoing project. I am excited to get started.
Unread 07-19-2014, 08:20 AM   #9
olliehopnoodle
1982 FSJ Cherokee
cool! Post up some pics. Welcome to the madness. Any plans? Restore, resto mod, wheel'n, camping trail rig or ??
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline   Reply With Quote
Unread 07-20-2014, 10:50 PM   #10
carnuck
1984 J-Series Truck
Saw your post on IFSJA.
Did I see one on FSJnetwork too?
FOR SALE STUFF
Unread Yesterday, 01:54 AM   #11
cometthedog
Nice rig
cometthedog is offline   Reply With Quote
