How do you trace wires from engine bay to gauges? -
Go Back > Models > Full Size Jeep Forum > How do you trace wires from engine bay to gauges?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueBlack Friday and Cyber Monday Sales at JeepHut.comThe Jeep Forum Discount is ON!
Unread 11-13-2015, 04:26 PM   #1
1984 J-Series Truck
I'm a newbie on the site. I have an '84 J-10. I received it in a trade. No engine, t179 4spd and rest of running gear in a basket case. I swapped in a Windsor 351. After I built mounts, It bolted right up to the tranny. I does however use a ford pressure plate and a Chevy clutch plate. Go figure? Anyway, I'm now working on wiring. I've got it the engine firing, but now I need some help on the gauge wiring.
Do I have to pull out the instrument cluster and check continuity or should I be able to apply a ground to the some of the engine sensor connectors?
I don't know for sure which ones are the sensor connectors for gauges or other modules. It looks like a spaghetti factory with all those wires.
Any help is appreciated.
Thomasmont is offline   Reply With Quote Quick reply to this message
Unread 11-16-2015, 12:14 AM   #2
1981 CJ7
You need the wiring diagram. has wiring diagrams for the 1984-1986 j trucks.
When i went through Mine I took the instrument cluster out so I could get to the big round plug on the back.
From there I was able to test each input in turn and track down the faults.
If it still doesn't work it may be cluster issues. Burnt and broken printed circuits are common but so are non-working gauges and voltage regulator.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread Today, 06:13 PM   #3
1978 FSJ Cherokee
X2 on
The wiring diagram helped me tremendously. It looks scary at first but once you figure it out it will save you lots of time. It will also save you from pulling wire that you don't really need. I had to learn the hard way and have wires to remove now. Just take it one step at a time and you will have it in top shape in no time.
MadMax78 is online now   Reply With Quote Quick reply to this message
In order to be able to post messages on the forums, you must first register.
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. is not in any way associated with Jeep or the Chrysler Corp.
