-   Full Size Jeep Forum (http://www.jeepforum.com/forum/f57/)
-   -   Homemade J-truck Camper Shell (pic heavy) (http://www.jeepforum.com/forum/f57/homemade-j-truck-camper-shell-pic-heavy-1466846/)
pleontks 01-21-2013 09:53 AM
4 Attachment(s)
Had been looking everywhere for a camper shell for my 76 J10 shortbed. I could find NOTHING!
Had an extra 79 Cherokee Chief (I know it was in good condition, but nobody wanted it)
pleontks 01-21-2013 09:55 AM
6 Attachment(s)
more pics...
pleontks 01-21-2013 09:57 AM
8 Attachment(s)
more pics....
pleontks 01-21-2013 10:05 AM
I cut off the top right below the seam where it goes back out under the windows. I cut it at a decent angle, with the inside cut being much lower than the outside, as the roof piece extends inches below the top of the side piece. I cut across the roof in about the middle of the doors (I measured like 15 times, but don't remember it now)
Once I got the roof off, I drilled out the spotwelds holding the side piece to the roof piece. I then attached s5' 2"x2" 16ga angle to the bottoms of the sides of the roof, starting at the rear. I had to trim some of the angle to clear the windows, as the bottom of the sides of the roof piece have a slant to them (Which I transferred to the camper shell. I attached it with tek screws (5/16 drive, #10?, 3/4", self-tapping). At the front, I finished framing the sides, and framed the front with 1"x1" 16ga angle.
The gaps in the sides I filled with some 24g I had laying around. I am still not sure what I want to put here. Would like to make it openable for access to the bed. I filled in the front with some strips of 16g. Pics in a bit.
I was moving out of state the day I finished it, so I scabbed in a back window from a trailer. No pics because it was nasty. Have the parts now to put on the same window, but with a lift hinge. Had to do some nasty stuff with the back corners to get the support I wanted, but will re-do that.
Also have a slider window for the front that I will install.
I used funnoodles as the cab-cap gasket.
Moved the furthest forward roof support beam forward a couple inches.
Ended up having to hack in a bunch of finishes, since I was moving the next day. Have been here just over a year, with no access to a welder, so no work done on the cap. I'm gonna pull off the angle from the sides, cut it nicely, and weld it back on. I also have some more welding to do at the front where the roof meets the 16g I put across the front.
Then it's just a couple decisions as to the back window, and what I wanna do on the front of the sides.
more to come...
Buster 01-21-2013 10:06 AM
Groovy, very fine work, and now you have a convertible chief! ;)
jeepdj5 01-21-2013 10:12 AM
Going to cry! I would have bought it
Sent from my fsj Cherokee chief using JeepForum
pleontks 01-21-2013 10:20 AM
Unfortunately, the body did not survive the surgery. Had to remove too much to get the whole roof piece out. Sides of chief floppped around like butter :)
Believe me, I felt bad. It had no engine and nobody wanted it. Tried parting it out, couldn't even sell the w/t axles.
But between my truck and the brown jeep in the pics, at least half of it still lives on :)
jeepdj5 01-21-2013 10:24 AM
Ok ( that makes me feel better ) you should put an engine in it and make a nice trail jeep
jeepdj5 01-21-2013 10:55 AM
Hey do you have the chief badges?
pleontks 01-21-2013 10:56 AM
2 Attachment(s)
here's the 16g on the front of it, and the window for the back.
So far, total budget of $0 (will keep it at that until I paint it)
And, after I cut the roof off the chief, took out the interior (went in brown jeep), and sold one of the rear axleshafts, picknpull came and picked it up, and gave me $200! A week later when I saw it in the yard, it was fenderless, doorless, and axleless.
jeepdj5 01-21-2013 11:03 AM
Where are you I need a fender, I said do you have the chief badges
pleontks 01-21-2013 11:06 AM
I'm in AZ, that jeep was in NV. The badges went to the brown jeep. Which I now regret, as my 77 needs a badge.
jeepdj5 01-21-2013 11:14 AM
Oh I need badges! Send them to me!
Marn 01-21-2013 03:33 PM
Oh goodness, that poor cherokee!
Looks like a neat shell though.
pleontks 06-27-2013 10:42 PM
Finally got a welder and start welding everything together. So far, the rail on one side is welded, and 2/3 ground. I'm not so good at welding yet. :)
Pics tomorrow.
The time now is 06:01 PM.
