help it wont start - JeepForum.com
post #1 of 5 Old 06-25-2010, 02:28 PM Thread Starter
jeepnumber2
1987 FSJ Wagoneer
help it wont start
87 Grand Wagoneer wont start.
I just bought it about two weeks ago. Drove it home 40 minutes on the interstate no problem. I tried to start it a couple days later and nothing. It still sits. It sounds like it wants to start but wont turn over. Some old guys in the neighborhood offered there two cents which was helpful. One checked the distributor and said I'm getting good spark, the battery is good. The fuel filter was good. So we tried gas down the carb and still wont start. With their advice I replaced the fuel pump and still nothing. It looks like fuel isn't getting to the pump. So is my problem somewhere from the tank to the pump? I keep trying fuel in the carb and it gets so close but just wont. Any help is greatly appreciated. Thanks
jeepnumber2 is offline
post #2 of 5 Old 06-25-2010, 03:19 PM
Eric1080
1978 J-Series Truck
gas in the tank. im serious. it happened to me. gauge was messed up said i had gas but was empty.
Eric1080 is offline
post #3 of 5 Old 06-25-2010, 05:57 PM Thread Starter
jeepnumber2
1987 FSJ Wagoneer
that was my next thought so I added a few gallons and the needle says over a 1/4 tank. You think I more still? thanks btw
post #4 of 5 Old 06-25-2010, 08:33 PM
gotmudnj
pull a fuel line off from the carb and have someone in the car...turn key and pump gas and see if anything comes out... when your cranking yous say it trys to start with starting fuel..does it kick over at all if you keep dumping gas it. i believe you said you tried and no luck. i would try starting fluid non stop while someone cranks it and see if you get anything.....just my 2cents...good luck
**** Happens.....
~~GOT MUD CENTRAL NEW JERSEY 4x4 ~~
gotmudnj is offline
post #5 of 5 Old 06-26-2010, 09:19 AM
Eric1080
1978 J-Series Truck
check the fuel pressure. maybe too much and flooding
Eric1080 is offline
76 j10 wont shift out of first :S riotstarter Full Size Jeep Forum 1 02-09-2010 09:59 AM
Help, waggy wont shift blownmope Full Size Jeep Forum 2 12-29-2009 08:54 AM
New motor keeps backfiring and wont start cmschule Full Size Jeep Forum 9 08-27-2009 11:40 AM
1988 Jeep wont start jeepster60 Full Size Jeep Forum 8 04-30-2009 11:59 AM
HELP ASAP: Having problems. It starts up when cold, once hot wont start. now shaking SomerJeep Full Size Jeep Forum 1 09-10-2007 06:58 PM
