Help Needed- Electrical ID, Grand Wagoneer - JeepForum.com
post #1 of 8 Old 04-26-2012, 04:15 PM Thread Starter
TNGWag
1989 FSJ Wagoneer
All,
Can anyone tell me what the small blue box located under the fuse box of a 1989 Grand Wagoneer is called and what it does? Also, I took a picture of it, but can't figure out how to post it, if anyone can tell me how to post, I'd be much obliged.
Thanks!
TNGWag is offline
post #2 of 8 Old 04-26-2012, 05:58 PM
DotJumper
1988 FSJ Wagoneer
It's the chime box...makes all the alarm sounds - key in ignition, door open, lights on, etc.
DotJumper is offline
post #3 of 8 Old 04-26-2012, 07:55 PM Thread Starter
TNGWag
1989 FSJ Wagoneer
Mystery solved- thanks for your help!
There is an unconnected wire in the mess of wires below the steering wheel that I want help identifying. I took a picture of it but can't figure out how to post the photo. Can anyone tell me how to add it?
Thanks.
TNGWag is offline
post #4 of 8 Old 07-24-2013, 06:31 PM
makulaf
reviving an old thread...
would this blue box be the problem with the door open/keys in the ignition warning being on all the time (even with no keys in the ignition)? can i just remove the box? thank you for any help
makulaf is offline
post #5 of 8 Old 07-24-2013, 06:45 PM
DotJumper
1988 FSJ Wagoneer
You can remove it and the sounds will stop. It could be the problem, but more likely is the switch inside the steering column has gone bad - stuck closed.
post #6 of 8 Old 07-25-2013, 11:54 AM
makulaf
thank you for the reply DotJumper. do you know if the switch in the steering column can be removed and if this is a big job?
makulaf is offline
post #7 of 8 Old 07-28-2013, 09:41 PM
DotJumper
1988 FSJ Wagoneer
It's not a huge job. Remove steering wheel. Tear it on down to ignition switch. The ignition alarm switch is there...if I remember right.
This is a GM steering column, so just Google "GM steering column rebuild". That's what I did when I bought my Jeep. Had to take it down to the tilt knuckle to tighten the bolts back up.
You can get a new one at Team Wagoneer: Steering Column Key Buzzer NOS GW 1979-1991.
http://www.teamgrandwagoneer.com/ste...-gw-1979-1991/
Let me know if you need any more help.
post #8 of 8 Old 07-29-2013, 07:47 PM
Little Green
1991 FSJ Wagoneer
I just replaced the cylinder ignition lock on mine so I was just in there. You need a steering wheel puller kit, more for the pressure plate than the actual wheel. Used the loaner tool at pep boys.
91 Grand Wagoneer(Winter vehicle/project)
Prior 08 Wrangler JK Lifted-Miss her
Little Green is offline
electrical issue , grand wagoneer , help needed , identification
89 Grand Wagoneer electrical help splitcane Full Size Jeep Forum 0 05-22-2011 02:41 PM
1989 Grand Wagoneer Electrical Issue miked2905 Full Size Jeep Forum 1 05-07-2011 08:37 AM
'88 Grand Wagoneer - Wiring / Electrical Issues 88GeeDub Full Size Jeep Forum 2 03-08-2011 12:42 PM
1988 Grand Wagoneer Electrical Problem jnc123ny Full Size Jeep Forum 3 03-31-2008 11:55 PM
88 Grand Wagoneer Electrical issue blubomber Full Size Jeep Forum 7 03-11-2007 11:52 PM
