help need to find a raditor for my 70 wagoneer - JeepForum.com
post #1 of 13 Old 08-30-2013, 01:15 AM Thread Starter
smooresfab
help I cant seem to find a radiator for my 70 wagoneer bought her for 500 bucks last week and after a few hours work new starter ect . just got her running and wouldn't you know it the radiator got a big hole didn't even see it when I bought her she has a buick 350 3 on the tree I checked all the autoparts stores autozone orillys napa ect cant seem to find one does anyone know where to get one or one thes close that will fit
smooresfab is offline
post #2 of 13 Old 08-30-2013, 11:42 AM Thread Starter
smooresfab
bump
post #3 of 13 Old 08-30-2013, 03:38 PM
pleontks
1976 J-Series Truck
welcome. Sweet deal. We want pics
Check bjsoffroad.com and teamgrandwagoneer.com
They're the main FSJ parts places. Also check summit, etc...
Beauty is in the eye of the jeepowner.
pleontks is offline
post #4 of 13 Old 08-30-2013, 04:19 PM Thread Starter
smooresfab
I tried those places with no luck even tried rock auto with no luck ps heres a pic 20130830_135626_resized.jpg
post #5 of 13 Old 08-30-2013, 08:06 PM
RockRollin
1990 FSJ Wagoneer
Not sure what else would fit. May have to get the old one rebuilt, repaired, or have the inlet and outlet swapped on a new one. Way cool Wagon, that Jeep emblem on the fender has always been top on my list
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #6 of 13 Old 08-30-2013, 08:11 PM
pleontks
1976 J-Series Truck
I've got 1 so far. The second one is eluding me.
pleontks is offline
post #7 of 13 Old 08-30-2013, 08:33 PM Thread Starter
smooresfab
Ive got both about to pull the radiator today
post #8 of 13 Old 08-30-2013, 09:40 PM Thread Starter
smooresfab
Damn thing sat for twenty year in a garage still nobody knows what radiator might fit someone has had to run into this problem before
post #9 of 13 Old 08-31-2013, 08:39 AM
CSP
Find a radiator shop. They may be able to repair the hole and if not they can point you in the right direction for a new one.
Have you checked to see if a radiator from a newer Wagoneer would work? The radiator support didn't hardly change over the years so a newer model may have a compatible radiator. The inlet/outlet position may be the only variable.
CSP is offline
post #10 of 13 Old 09-04-2013, 11:40 AM Thread Starter
smooresfab
as far as I can tell the 73 radiator the inlet and outlets r just swaped and the brackets make it set away from the engine a inch or so more but other than that there the same how difficult is it to swap the inlet and outlet anything special than just moving them I can get a aluminum one for 150 bucks
post #11 of 13 Old 09-04-2013, 02:27 PM
CSP
Any decent radiator shop can swap the inlet/outlet. I'd find such a shop before purchasing a radiator though and make sure to tell them what material it's made of.
CSP is offline
post #12 of 13 Old 09-05-2013, 08:56 PM
strvger01
1966 CJ5
wow, yours looks a lot like my 1966! mine has the 327 vigilante v8 with the 3-on-the-tree tranny. i agree with pulling it and taking it to a radiator shop. will probably just be easier and cheaper to have them rebuild yours. good luck for sure.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #13 of 13 Old 09-05-2013, 10:28 PM
sailorjim
possible radiator option
I have a '66 and a '68 I am working on. The '66 came with a 327 and has a narrower radiator support. I need a new radiator as well and it looks like one for the late 60's early 70's GMC trucks should fit with the right hose size and placement. Seems like they are about $300. Just find a parts store that still uses catalogs and double check the picture.
sailorjim is offline
