help with my chief. - JeepForum.com
post #1 of 66 Old 03-11-2013, 08:26 PM Thread Starter
93ZJDave
help with my chief.
So i started on my chief and it hasnt been touched it over 20 years the wiring harness is a mess so i replaced the harness with a spare i still cant seem to get the motor to turn over i tried everything and cant seem to even get it to click any idea what im doing wrong? Maybe something isnt grounded right i even tried jumping the solenoid and nothing
93ZJDave is offline
post #2 of 66 Old 03-11-2013, 09:50 PM
dbabicky
1975 J-Series Truck
Have you tried to manually turn it over with a breaker bar/socket on the crank?
Why me, Why me !!!
dbabicky is offline
post #3 of 66 Old 03-11-2013, 10:59 PM Thread Starter
93ZJDave
Yeah i had the motor down to bare block it turns by hand but the electrical its kinda a mess my uncle started a frame up 22 years ago and i got it now to finish it and well its a mess lol i have a chilton manual which helps a bit im pretty sure the harness is wired right i cant get the starter to work i have a spare starter and it dont work either i gotta be missing something
93ZJDave is offline
post #4 of 66 Old 03-11-2013, 11:35 PM
pleontks
1976 J-Series Truck
We totally need the year
For the starter to go, you have wire from battery to solenoid, large wire from other side of solenoid to starter, and groudf from starter/engine to battery. You already know how to jump the solenoid, so if you have those wires and good connection, you should be able to get the starter to engage.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #5 of 66 Old 03-12-2013, 10:52 AM Thread Starter
93ZJDave
Sorry its a 1979 chief with a 360 quadratrac and th400. I have the wire from the battery to the solenoid then from the solenoid to the starter i have the negative going to a bolt on the head and the smaller wire grounded on the fender well. I can get the solenoid to click but thats it but thats when i jump power to the smaller post on the top of the solenoid if i jump it from post to post to bypass the solenoid nothing happens.
93ZJDave is offline
post #6 of 66 Old 03-12-2013, 04:49 PM
pleontks
1976 J-Series Truck
Check for continuity on your wires. They could be broken in the middle and look fine.
pleontks is offline
post #7 of 66 Old 03-12-2013, 05:46 PM
RockRollin
1990 FSJ Wagoneer
Has either starter been bench tested? Have you checked the solenoid wire for continuity?
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #8 of 66 Old 03-12-2013, 06:07 PM Thread Starter
93ZJDave
93ZJDave is offline
post #9 of 66 Old 03-12-2013, 06:15 PM Thread Starter
93ZJDave
No i havent done any of that im new to this jeep it tried jumping both starters with jumper cables ground on the body and positive on the terminal and nothing im not sure what up maybe i have a bad ground or something the jeep was a project of my uncle and he never finished it sat since 1990 untouched so who know whats wrong i tried startingnit witg the key only the brake lights comes on. The jeep its stripped right now so there not much in or on it most of the wiring isnt installed.
93ZJDave is offline
post #10 of 66 Old 03-12-2013, 07:23 PM
RockRollin
1990 FSJ Wagoneer
I would make sure the starters are working before I started chasing wires. Chasing shorts is my least favorite thing on a vehicle btw
"I like fun" Edd
post #11 of 66 Old 03-12-2013, 07:28 PM Thread Starter
93ZJDave
Is there a way to see if a starters good or should i just take it to get it tested? 20 years ago when they were working on it everything was new so pretty much everything was new 20 years ago but that dont mean much.
93ZJDave is offline
post #12 of 66 Old 03-12-2013, 09:05 PM
RockRollin
1990 FSJ Wagoneer
Could take it in and test. I've done it with jumper cables, but it always has spooked me a little
"I like fun" Edd
post #13 of 66 Old 03-12-2013, 09:17 PM Thread Starter
93ZJDave
I tried jumper cables on both the starters i have i clip the negative to a bolt ear on the start and positive to the brass post on it and and i get nothing maybe from sitting there shot
93ZJDave is offline
post #14 of 66 Old 03-14-2013, 12:39 AM
dbabicky
1975 J-Series Truck
Starter's shot !
Why me, Why me !!!
dbabicky is offline
post #15 of 66 Old 03-14-2013, 11:36 AM Thread Starter
93ZJDave
I had a feeling it was ill look into a new one figures that i have 2 here and they are both bad.
93ZJDave is offline
