Help with exhaust y pipe piece - JeepForum.com
post #1 of 6 Old 02-10-2013, 01:28 PM Thread Starter
Little Green
1991 FSJ Wagoneer
So I am in the process of replacing the y pipe for the exhaust. Of course 3 of the 4 bolts break off but I am trying to figure out what the Attached piece is. It looks like it has a butterfly in it but the spring is shot and it clearly does not work. Any ideas? Is it needed?
Thanks
91 Grand Wagoneer(Winter vehicle/project)
Prior 08 Wrangler JK Lifted-Miss her
Little Green is offline
post #2 of 6 Old 02-10-2013, 04:30 PM
RockRollin
1990 FSJ Wagoneer
I removed the butterfly and welded the holes. Its for warmup, butterfly closed when cold causing back pressure.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #3 of 6 Old 02-10-2013, 05:48 PM Thread Starter
Little Green
1991 FSJ Wagoneer
Welded which holes? Thanks
Caesar
post #4 of 6 Old 02-10-2013, 06:21 PM
RockRollin
1990 FSJ Wagoneer
The butterfly shaft holes. You could tap the holes a thread a bolt if no welder available, but welding would be best option.
"I like fun" Edd
post #5 of 6 Old 02-10-2013, 08:06 PM
BJ's Off-Road
1979 FSJ Cherokee
It is an exhaust damper. When cold, it is closed and it forces that sides exhaust through the intake manifold and out the other side of the exhaust. A lot of people just weld them open.
BJ's Off-Road is offline
post #6 of 6 Old 02-10-2013, 10:19 PM
pleontks
1976 J-Series Truck
ties into that little metal tube that goes into the bottom of your air cleaner.
My was cracked in half. I removed it. Not a good idea. I twisted my y-pipe and the whole exhaust. Was a horrible pain to get donut to seal.
Definetly suggest putting it back in. With or without butterfly.
Beauty is in the eye of the jeepowner.
pleontks is offline
