help Emergency drive will not disengage - JeepForum.com
post #1 of 10 Old 04-15-2013, 10:53 AM Thread Starter
cookingguy
1979 FSJ Cherokee
So I when 4xing yesterday and at the end of the day when I went to go back to two wheel drive it will not disengage. So I just unlocked the hubs and drove home. Please help with any ideas on how to get this back in two wheel drive. I have the qudra trac part time system
cookingguy is offline
post #2 of 10 Old 04-15-2013, 02:32 PM
79chiefs
1988 XJ Cherokee
I thought Quadra trac is full time not part as i read most places, and been told, and it says so in my dash, so it is always in 4wd, but there is normal, and emergency drive it could be stuck in e drive as mine had been.
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #3 of 10 Old 04-15-2013, 02:48 PM Thread Starter
cookingguy
1979 FSJ Cherokee
They made a conversion kit for the Quadra trac to make it a part time 4 wheel drive system and that Is what I have. I know this because of the sticker in my glove box and the fact I have hubs I have to turn to lock to make it 4 wheel drive
post #4 of 10 Old 04-15-2013, 03:04 PM
lucdog
lucdog's Avatar
1980 CJ5
I'd start by checking for vacuum leaks, at the engine connection first, then the rest of the hard lines as well as the rubber ones. The vacuum switch (it's actually a valve) connections need checked also.
If no leaks, I would use a vacuum pump at the engage motor apply side, at the TC to see if its working. Or run a Dedicated vac. line from manifold vac. to the TC. Remember one of the lines from the firewall to the TC is a vent line.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5 of 10 Old 04-15-2013, 03:20 PM Thread Starter
cookingguy
1979 FSJ Cherokee
Where do the vac line connect at the engine???
post #6 of 10 Old 04-15-2013, 05:28 PM Thread Starter
cookingguy
1979 FSJ Cherokee
So are all three of the tubes coming from the switch in the glove box susposed to be conected to somthing cause on is not and it looks like it should be hooked up somwhere
post #7 of 10 Old 04-15-2013, 05:49 PM
79chiefs
1988 XJ Cherokee
from the switch two go down to the transfer case and one into the engine compartment to the vacuum canister for the vacuum pressure
95 E34 540i-DD
79chiefs is offline
post #8 of 10 Old 04-15-2013, 06:08 PM
79chiefs
1988 XJ Cherokee
The engine compartment shows the vacuum canister location(black canister middle of firewall)
The second shows the diaphragm on the t-case where the other two lines hook up circular item with red nipples, if the diaphragm is bad you cannot buy a replacement that i have found, mine is bad.
95 E34 540i-DD
79chiefs is offline
post #9 of 10 Old 04-15-2013, 06:17 PM
lucdog
lucdog's Avatar
1980 CJ5
If you haven't read the info on this link.
http://jubileejeeps.org/quadratrac/index.htm
You need to. Not sure on J Trucks or Waggys but the vacuum supply on a CJ's comes from the intake manifold, just behind the carburetor.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #10 of 10 Old 04-16-2013, 02:25 PM Thread Starter
cookingguy
1979 FSJ Cherokee
thanks for the help guys got it fixed this morning. It was a vac line not hooked up. Thanks again guys
