Help! 79 J10 - JeepForum.com
post #1 of 7 Old 11-20-2011, 06:00 AM Thread Starter
Fatmatt81
Help! 79 J10
I have a 79 j10 with the amc 360. I am having a problem with the distributor drive gear. It was grinded down and in one spot the teeth were completely gone. Wouldn't it grind all of it the same.
Fatmatt81 is offline
post #2 of 7 Old 11-21-2011, 11:21 AM
revelc
1985 FSJ Wagoneer
Can you use a mirror and see if the cam gears are worn as well? You might have some bigger problems than just a distributor shaft.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #3 of 7 Old 11-22-2011, 04:56 AM Thread Starter
Fatmatt81
I have the casing off. The distributor is fine the gear on the cam shaft is worn bad. All the teeth on the main distributor gear are worn were they are razor sharp and a 1/4 of the gear is missing all the teeth
post #4 of 7 Old 11-22-2011, 12:25 PM
revelc
1985 FSJ Wagoneer
Well, we can be positive about this. Now you have an excuse for an rv cam and a DUI ignition system.
revelc is offline
post #5 of 7 Old 11-22-2011, 07:50 PM
carnuck
1984 J-Series Truck
That gear bolts on separately. Sounds like either the oil pump was seizing up (got a Fram filter on it?) or the cam was walking and ruined the gears.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #6 of 7 Old 11-22-2011, 08:39 PM
revelc
1985 FSJ Wagoneer
It can be anything until you tear into it.
revelc is offline
post #7 of 7 Old 11-22-2011, 10:36 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
New timing gear/chain set should fix things up?
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
