heeeeeeeeelp - JeepForum.com
View Poll Results: heats up then shuts down tried 4 things
help is greatly needed 2 66.67%
green horn 1 33.33%
Voters: 3. You may not vote on this poll
post #1 of 3 Old 12-26-2003, 12:21 AM Thread Starter
Darcy L Unger
heeeeeeeeelp
Hi I'm Darcy I have a 87 Wagoneer my father-in-law found the truck for 300 bucks.It run like a top not good for the road.My neighbor and I made it into a snowplow.To make a long story short when it heats up it shuts down.I replaced the coil and the module under the coil,the cap and rotor,the fuel filter,and I pulled the alternator out and had it checked and it was good.I have a bigger battery in her but last year it ran fine with it. I am not very mechanically inclined{green horn}.I even phoned the jeep dealer but they didnt know.{yeah right bring it in I dont think so}.But the fuel pump,pumps as soon as it stops running when I turn the key to on.My brother-in-law told me a few things and suggested I go to Jeep Forum.I was hoping that someone out there had the same problem so I could fix mine before I get more snow thank you so much Darcy
Darcy L Unger is offline
post #2 of 3 Old 12-29-2003, 09:17 AM
Anti-Chrysler
I can almost 100% guarantee that it's the ignition module on the driver's side fender. Unfortunately, your '87 will have weather-pak style connectors, and the module will therefore cost around $80. It's a Ford module and fails quite often, and often under the circumstances you describe. PM me for more information if you need it.
Anti-Chrysler is offline
post #3 of 3 Old 01-02-2004, 09:20 AM Thread Starter
Darcy L Unger
Thanks alot,on the driver side fender?What does the ignition modual look like, is it under the window cleaner bucket?Sorry but I'm a green horn.There is another part that has little hoses coming out and in with a little box 1in. buy 1 in. with about 5 posts on it ,it looks like a fuse or something.
