Head swap - JeepForum.com
post #1 of 7 Old 04-21-2013, 09:40 PM Thread Starter
paulbone
1977 FSJ Cherokee
Head swap
Hi Guys
I have a good pair of rebuilt 360 heads from an 83 Chief and was going to use them on my 76 Chief.
Question is, the valve springs on the 76 are slighty longer and tighter than the ones on the 83 head.
Should I swap the springs over, or keep the 83 heads intact as they are.
Background;
The 76 is low milage snow plough, (40,000) but the heads are very badly carboned up, three push rods are bent into an S shape and several manifold studs sheared off. The truck has been sat for many years til I got hold of it.
Appreciate any advice.
Any advice would be appreciated.
paulbone is offline
post #2 of 7 Old 04-22-2013, 12:34 AM
revelc
1985 FSJ Wagoneer
You should mic the cams and see if one is an aftermarket one thus requiring different springs.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #3 of 7 Old 04-22-2013, 02:34 AM
pleontks
1976 J-Series Truck
check the holes for the bolts for your accessories. jeep changed the size around 80
Beauty is in the eye of the jeepowner.
pleontks is offline
post #4 of 7 Old 04-22-2013, 09:23 PM Thread Starter
paulbone
1977 FSJ Cherokee
Thanks for your input.
The accessory holes all match up thankfuly.
I have since discovered that the spring lengths were changed in the 80's, anyone know why? The cam size didn't seem to change though?
I think I will put a new cam in anyway now after seeing that the lifters have a flat base.
Now to decide what cam to go for, hhhmmmmm?
paulbone is offline
post #5 of 7 Old 04-22-2013, 09:40 PM
super98lsc
Honestly, you need to check the seat pressures and ensure they match the cam specs. example, you run too light of spring and it will float the valves before peak power and run like crap. If they are too tight you will wipe the lobes right of the cam in 500 miles. Of course coil bind is important too. Higher lift binds coils then you break springs and drop valves kaboom.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #6 of 7 Old 04-23-2013, 02:54 AM
RockRollin
1990 FSJ Wagoneer
Replace springs with correct springs for cam everytime. Not much more $, cheaper than pullin it apart again, and no wondering
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #7 of 7 Old 04-23-2013, 08:35 PM Thread Starter
paulbone
1977 FSJ Cherokee
Thanks for the advice gents.
I pulled the cam today and its right on the limit for wear.
Tonight I'm going to order a new cam with matching springs, timing gear etc.
That way i'll have peace of mind.
I'm after total dependability over perfromance, as I aim to treck down to South America in it when she's done.
paulbone is offline
