GW rear 44 with older Waggy front? - JeepForum.com
post #1 of 8 Old 05-08-2010, 10:41 AM Thread Starter
jp360cj
1977 CJ7
I think I found some axles to swap in my CJ. Found a passenger drop front from a Wagoneer and rear from a Grand Waggy. Both are D44s. I believe the front should be a NT (haven't been able to go look at it yet). Will they be close to the same width to use together?
I looked at the chart under the sticky, but some of the measurements were all over the place. Oh and I don't want to cut them down b/c I want a wider stance for my NT CJ.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #2 of 8 Old 05-08-2010, 11:14 AM
BJ's Off-Road
1979 FSJ Cherokee
Yes, they should be close enough to the same width if they were both narrowtrack but if we knew a year or the BOM from the front axle I could tell you for sure.
www.bjsoffroad.com
BJ's Off-Road is offline
post #3 of 8 Old 05-08-2010, 11:32 AM Thread Starter
jp360cj
1977 CJ7
Not sure about the front. I just know it came out of a Wagoneer with Q-trac. The guy was going to use it under his CJ5, but he went CJ WT instead. Saw the rear at a junkyard yesterday under a Grand Waggy, but didn't have time to check it out.
jp360cj is offline
post #4 of 8 Old 05-09-2010, 09:39 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
FSJ NT axles are (IMO) the perfect choice for a medium-duty CJ. The front is what you want - it probably just doesn't have lockouts on it. They are easily swapped in. You are correct that the 86-up Grand Wagoneer D44 is the axle you want to match with the front. It is the same WMS as the rear from the 70's and matches the front you have (think its about 58"-59"), so go get it.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #5 of 8 Old 05-09-2010, 10:38 AM Thread Starter
jp360cj
1977 CJ7
Thanks PavementPounder...that's what I was hoping to hear.Going to swap to 5x5.5" so not worried about no lockouts
jp360cj is offline
post #6 of 8 Old 05-09-2010, 11:09 AM
PavementPounder
Cool as Ice...
In that case, I probably would not bother with the FSJ D44 rear. Go get a Scout D44 rear that is already 5x5.5". Should be 58" WMS. Add 1/2" spacers if you want.
I'd consider buying new wheels as an alternate plan. Buying new ones for the 6x5.5" FSJ pattern and selling your old wheels will probably be cheaper than the conversions and you'll have the opportunity to re-choose both wheel style, width, and backspacing to best fit the new axles.
post #7 of 8 Old 05-10-2010, 09:32 AM
CSP
Since one is a Waggy axle and the other from a Grand Waggy they are both narrow track.
Only the J-trucks and Cherokee Chief models had wide track axles.
CSP is offline
post #8 of 8 Old 05-10-2010, 11:15 PM Thread Starter
jp360cj
1977 CJ7
Thanks yall. I'll probably end up going with a Scout rear for the 5 lug. I don't really want to have to buy new rims and i've already got the hubs from my dad's old Ford for the front.
jp360cj is offline
Front Grand Waggy Dana 44 breather hose foggybottombob Full Size Jeep Forum 6 08-06-2009 02:04 PM
What's the width of a waggy front axle? wheelinjames Full Size Jeep Forum 6 03-03-2008 06:48 PM
Don't know year, waggy D44 front balljoints Blthomas Full Size Jeep Forum 2 02-18-2007 01:27 PM
Got stock front waggy springs? bluemj Full Size Jeep Forum 0 12-20-2006 12:24 PM
Waggy rear leaf length? 18to80DDC Full Size Jeep Forum 0 06-21-2006 01:36 PM
