Grand Wagoneer Woodgrain Trim - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Grand Wagoneer Woodgrain Trim
USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4FS: Jeep Fog Light LED Bulbs! Several Brightness Options! The Ruffstuff 9" Disc Brake brackets!
Unread 07-12-2015, 07:49 AM   #1
rmcwhorter
1989 FSJ Wagoneer
Ho w do I remove refresh and reattach the woodgrain trim on my Grand Wagoneer
rmcwhorter is offline   Reply With Quote Quick reply to this message
Unread 07-13-2015, 08:17 AM   #2
GCX2450
1989 FSJ Wagoneer
Refresh? If it's faded and/or worn through then the only real option is replacement. Otherwise there is no need to remove it and it can be cleaned on the truck.
GCX2450 is offline   Reply With Quote Quick reply to this message
Unread 07-25-2015, 07:53 PM   #3
tensley
1991 FSJ Wagoneer
I had some really nasty wood trim on my 91. I tried all sorts of cleaners. From cleaner sprays to the Citrus wipes. Nothing worked. Then I was out working on the carpet and My wife had left a Magic Eraser near the hose. I grabbed it rinsed it off, rang it out but not all the way and just wiped it on the trim. It was literally like night and day. All that old mildew, sap, and other things came right off. Also it did no, I mean zero damage to the trim. I have since then used it my leather seats, seat belts, dash, and my a/c vents. I hope this helps.
tensley is offline   Reply With Quote Quick reply to this message
Unread 07-26-2015, 08:07 PM   #4
BugsInMyTeeth
1964 FSJ Wagoneer
I had a gf about a decade ago that cleaned houses for a-living and she swore by those magic erasers.
Jeep... real good at goin slow
BugsInMyTeeth is offline   Reply With Quote Quick reply to this message
Unread 08-02-2015, 08:51 PM   #5
lucdog
lucdog's Avatar
1980 CJ5
My wife uses these for a number of cleaning projects. After a good look at them, they appear to be a very very very fine scotch bright pad. . She also uses them on the seats in our boat, I have not noticed any adverse affects from them.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is online now   Reply With Quote Quick reply to this message
