Grand Wagoneer Won't Start - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Grand Wagoneer Won't Start
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineMemorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender Flares
Unread 05-26-2010, 11:32 PM   #1
JustinPolley
1988 FSJ Wagoneer
I have an 88 Grand Wagoneer with 500 mile on a rebuild. It just won't start, I was diving it and it just stopped running and won't fire back up. It seems to try to fire when I let go of the key. I have replaced the connectors on the coil, the coil the cap and the rotor. When i attach the connectors on the coil i get a spark, when i pull the wire from the coil to the distributor i get a spark (but only right when the key turns and right when its let go but no fire in between).No spark at the plugs. plugs and wires only have 500 miles, halifax 400. I messed with it all day and can't get it to start.
JustinPolley is offline   Reply With Quote
Unread 05-27-2010, 05:27 AM   #2
megajeep
1989 FSJ Wagoneer
Why it quit while running i can't say, but I have a similar starting problem with both my jeep and my motorcycle when my battery is weak. It seems that there is enough power to turn the starter, but the ignition isn't getting enough juice to fire until the moment I let go of the key and the ignition gets the power it needs.
It that case it always starts with the help of my battery charger on 50 amp start setting.
I have a drain in my jeep that kills my battery if I have my dome light fuse installed and have had plenty of experience with a weak battery.
So to me it sounds like a problem with the battery, regulator, or ignition module.
There is also a resistor wire that can go bad and cause ignition problems. Its a red wire with a gold stripe. I believe the symptom of it going bad is a good start cold then runs bad or quits after it gets warmed up and progresses to not starting at all. The wire is located in the engine harness. It starts in a slice up at the firewall and ends in a slice down by the front of the engine before it reaches the coil.
megajeep is offline   Reply With Quote
Unread 05-27-2010, 09:37 AM   #3
JustinPolley
1988 FSJ Wagoneer
Still won't go
Charged the battery, replaces the ECM still nothing. Not sure what regulator your talking about.
Unread 05-27-2010, 09:44 AM   #4
JustinPolley
1988 FSJ Wagoneer
If you're talking about the voltage regulator in the alternator the whole unit is brand new.
Unread 05-27-2010, 11:11 AM   #5
BioTex
OIIIIO
BioTex's Avatar
I remember reading about why the engine fires when you let go of the key.
JeepHammer over on the CJ forum told me why a couple of years ago, but can't remember the details.
Had something to do with voltage drop due to cranking, and a resistor or resistor wire was supposed to fix this. I did a quick search, but could not find that post.
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
1986 CJ10-A SD-33 Diesel/727/np208
1971 800B with 345/T-19
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
YJ Buggy Build Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline   Reply With Quote
Unread 06-09-2010, 11:36 PM   #6
carnuck
1984 J-Series Truck
Could be burnt ignition resistor wire (power directly the the coil + will fire it up) or bad pickup coil in the dist
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
http://tinyurl.com/jimsclads
'82 Honcho Sportside project 360 4 speed NP208 $1500
'81 Eagle wagon with upgrades $2800
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3000
carnuck is offline   Reply With Quote
