Grand Wagoneer Fuel Line - JeepForum.com
post #1 of 4 Old 09-16-2017, 12:42 AM Thread Starter
SPDUFFEE
Hello All,
I am cleaning my entire fuel system - cleaning the tank, replacing fuel lines, etc.. Can anyone tell me the correct o.d. of the rubber fuel line needed and approximately how much I will need, in linear feet?
Thank you!
Shawn
SPDUFFEE is offline
post #2 of 4 Old 09-18-2017, 08:21 PM
WeeeeeGoneEr
Newbie
WeeeeeGoneEr's Avatar
check bjsoffroad.com for the tank specific lines.
The long lines are steel and am not sure they need to be replaced. The remainder (like from the steel lines to the fuelpump / filter / carb), just bring a sample of the line so your local shop can match the ID.
Portland, OR
1984 GW
Rebuilt 360
NWMP 21G aux tank|Performer Cam/Intake|Holley SA 670|MSD 8519/Mr. Gasket can|Dakota Digital VHX custom printed/programmed|Z&M Engine Harness|Serehill Relay Headlight Harness|H4 conversion|Mopar deep tranny pan|K&M oil filter|SPOT GPS tracker|Ammeter Bypass
WeeeeeGoneEr is offline
post #3 of 4 Old 09-19-2017, 05:35 AM
paintballtruck
1979 J-Series Truck
they use 3/8ths for the supply and I believe 1/4 for the return
paintballtruck is offline
post #4 of 4 Old 09-20-2017, 09:17 PM Thread Starter
SPDUFFEE
Ok, thank you!
SPDUFFEE is offline
