Got lots of body work done - JeepForum.com
post #1 of 8 Old 06-01-2004, 06:07 PM Thread Starter
Drix
I got a bit of body work dont on the Jeep this weekend i got the hood sanded and primered down and i got some nasty rusy spots out and bondo-ed then back so it looks good agian. also i got the windows all taped off so its fun driving it in and out of my garage lol
Drix is offline
post #2 of 8 Old 06-08-2004, 04:11 PM Thread Starter
Drix
finally finished the body work and got it primared i still need to stip the tailgate down and get that in good order. probly will have to cut out a ton-o-rust and weld some new metal in to it. but i have nothing else to do this week so ill get that done ill get some pics up you can see the before and after.
Drix is offline
post #3 of 8 Old 06-13-2004, 11:25 PM Thread Starter
Drix
ok im most of the way done i got all the body work i can do done ill have to get my buddy to do the rest. i accually have the modling on and the mirror and the badges. i think im gonna take the badges off and make them look a little new agian. but here is my most recent pictures there is also some before and now the after so u can see the diffrence.
My Jeep
Drix is offline
post #4 of 8 Old 06-15-2004, 02:01 PM
FSJeepin'
I'm doing the body work on my '91 Waggy and it's about half done. Not as easy as I thuoght it would be but it's not so bad I guess. Nice work on yours man, keep at it.......Rob
It's always worth the gas
FSJeepin' is offline
post #5 of 8 Old 06-17-2004, 08:54 AM Thread Starter
Drix
thanks man. body work just time consuming. all i used to make it easier is a power drill non cordless. and i bought some 3M sanding pads they work better. also i used a slide hammer to pull the dents out. I cut the major rust spots out with a dremel tool and cutting discs nocked out the rust with a screw driver. i used some chemical stuff that prevents rust dont know what it is called though. and to smoth out the sanding i used an electric Jitterbug if u know what that is. i think the real name is palm sander
Drix is offline
post #6 of 8 Old 06-18-2004, 09:39 PM
truckerdirt
looks good man. i wish i could afford to keep mine and buil it up; but i'm haveing to sell it now.
truckerdirt is offline
post #7 of 8 Old 06-21-2004, 10:56 AM
FSJeepin'
Drix, how did you fill your holes where you had to cut it out? I used fiberglass, it seems to work well but don't know if she'll hold up though. All I did was paint over were the rust spots were (grinded to bare metal, light body fill to smooth,then I painted) do you think that will rust out, or should I use the stop rust stuff first?
post #8 of 8 Old 06-22-2004, 09:36 AM Thread Starter
Drix
My holes were not that big i used bondo. bondo gets heavy though fiber glass is good i dont know how it holds on to the metal though i have never used it. but i know it is flexable and will not break like the bondo. if u have major size hole that u cut out i suggest welding a new piece of metal in there and sanding down the bead so it is smooth. but if your holes are small enough i would just use some bondo. u cant mess it up if u do u can just sand it off and do it agian.
Drix is offline
Making some M715 progress Lots of Pics poolmike Full Size Jeep Forum 101 03-10-2013 06:59 PM
What is this and how does it work? ccpanel Full Size Jeep Forum 8 03-03-2009 04:44 AM
how does the tank selector work? ifurlong Full Size Jeep Forum 1 10-08-2008 08:33 AM
Lots of Generic Questions... slimpeimp Full Size Jeep Forum 2 04-25-2007 12:50 PM
Heater fan does not work Custom RooR Full Size Jeep Forum 1 03-19-2007 12:09 AM
