Got Laid off Monday- Time to hop up the 360!!! - Page 2 - JeepForum.com
post #16 of 43 Old 04-23-2013, 07:11 PM
RockRollin
1990 FSJ Wagoneer
Originally Posted by revelc View Post
Unfortunately I haven't heard anything good about cheap headers. The people that have made them work had to mess with them. Like cutting the flanges between each port, cutting grooves around each port, or just throwing them out and getting Doug's.
As far as fitment I am not sure.
I am about to learn how to port and do a valve job myself. I am excited to learn about this stuff
I've read much of the same about the "cheap" headers. Lousy transitions, complete replacement of the flange. Get the Thorleys! They will match the dog leg.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #17 of 43 Old 04-23-2013, 09:54 PM
revelc
1985 FSJ Wagoneer
How about he runs open hooders and flips the manifolds upside down
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #18 of 43 Old 04-23-2013, 10:05 PM Thread Starter
super98lsc
Only if I bolt a couple of 76mm turbos on em
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #19 of 43 Old 04-24-2013, 02:49 AM
RockRollin
1990 FSJ Wagoneer
Solid strait axle, lets just go GW Gasser.
"I like fun" Edd
post #20 of 43 Old 04-24-2013, 06:31 AM
revelc
1985 FSJ Wagoneer
You've watched too many Nelson Racing clipson YouTube lol
revelc is offline
post #21 of 43 Old 04-24-2013, 07:33 AM Thread Starter
super98lsc
My best friend owns underground racing in Charlotte NC, 1800 rwhp all wheel drive Lamborghinis, Ferarris, some Vipers. Insane acceleration cars that drive like stock on the street until you open the throttles a little more.... Then its like a Saturn rocket engaged and wel..... first time I launched one I started to lose consciousness by third gear. These things will run 6.80's in the quarter! All wheel drive. hmmmn wagons all wheel. Rofl
post #22 of 43 Old 04-24-2013, 08:22 AM
revelc
1985 FSJ Wagoneer
Ghimni would definitely have to step his game up ROFL!
revelc is offline
post #23 of 43 Old 04-24-2013, 05:04 PM Thread Starter
super98lsc
One thing makes just no sense to me this current setup is it pops back up the and runs like complete crap unless my base timing is 20+deg!! Perhaps ill degree the old cam before I pull it this makes no sense. 38deg advance mechanical total. It would explain the bad vaccum signal yet not sounding cammed, or timing set off a tooth. Someone playing backyard engineer decided to adjust cam timing by skipping teeth and a sun dial vs adjustable.timing set and degree wheel???? :-)
There is no way this thing should run 180 out. I'm guessing either the previous rebuilder did something really awkward with the cam timing and or this timing chain is stretched out a few feet rofl.
post #24 of 43 Old 04-24-2013, 08:04 PM Thread Starter
super98lsc
I love summit boxes!!
post #25 of 43 Old 04-24-2013, 10:49 PM
revelc
1985 FSJ Wagoneer
Me too. Have you used the intake rubber gaskets before? They are best used for higher rising intakes. AMC guys warn us to stick with the valley pan. Just sayin..
revelc is offline
post #26 of 43 Old 04-25-2013, 02:43 AM
RockRollin
1990 FSJ Wagoneer
Correct, valley pan only. The fiber gaskets will make it very difficult to get the bolts in, also causing massive gaps at the end seals. Use only RTV at the end seals, no rubber.
"I like fun" Edd
post #27 of 43 Old 04-25-2013, 06:46 AM Thread Starter
super98lsc
Sounds the same as the olds motors. Ive never used the rubber ends only.rtv. My intake does not have egr or heat passages. What purpose is the valley pan? Stock or heat passage intake I know it keeps oil from coking to the bottom side of the intake and likely helps keep the oil cooler vs it hitting that hot exhaust crossover.
post #28 of 43 Old 04-25-2013, 07:24 AM
revelc
1985 FSJ Wagoneer
It helps prevent oil coking, but doesn't stop it completely.
It also keep hot oil from splashing up, heating the incoming air, thus reducing overall efficiency.
revelc is offline
post #29 of 43 Old 04-25-2013, 07:51 AM Thread Starter
super98lsc
On a normal intake yes, air gap no. air gap has a built in valley pan if you will. The plenum, runners, etc have an open air gap between them and the bottom of the intake. Ill snap a picture in a bit.
post #30 of 43 Old 04-25-2013, 08:01 AM
revelc
1985 FSJ Wagoneer
Shucks. For some reason I thought you were running a performer! Sorry bud.
And your right. I've even heard running a Performer RPM doesn't require one.
revelc is offline
