Gladiator J100 - JeepForum.com
post #1 of 2 Old 11-13-2009, 09:54 AM Thread Starter
tomis
Gladiator J100
Ive got a buddy that will give me a set of Gladiator J100 axels. Does anyone have any information on these. I know they are the same bolt pattern as a YJ but i dont know how wide, and front diff, if its driver or passanger side drop. I searched and couldnt find any info on them.
tomis is offline
post #2 of 2 Old 11-13-2009, 01:56 PM
Pathkiller
1974 CJ5
You couldn't find any info because it doesn't exist. There's no such thing as a Gladiator J100. The later Jeep trucks dropped the Gladiator name and used the J10 and J20 designation (half and 3/4 ton). If it's a 74-86 version it's probably a J10, which has Dana 44 front and usually Dana 44 rears, but some 80's versions used an AMC20 rear. Not the same AMC20 used in CJ's, the J-truck version has one piece axles and a stronger housing. 74-79 will be Dana 44's with a passenger's side front offset. The rears may be offset if they came with the Quadratrac case. All J-truck axles are extremely wide for use in a YJ, around 67" wide at the WMS.
If it's a 73 or earlier model you don't want the axles, they are closed knuckle fronts and not worth the swap.
No J-truck ever used a bolt patter that is the same as a YJ, by the way. If they're 74 and newer they will be 6-lug. 73 and earlier would be 5x5.5", same as CJ's.
By the way, there was a J100, but it wasn't a Gladiator truck. It was a panel delivery truck, which was essentially a 2 door Wagoneer with no side windows and a barn door rear door. They are very rare and it's highly doubtful that this is what your buddy has.
Pathkiller is offline
Gladiator question 81CJ8 Full Size Jeep Forum 6 02-06-2010 07:29 PM
Gladiator engine T-Maxxman1 Full Size Jeep Forum 5 03-26-2009 03:45 PM
66 Gladiator Parts docque Full Size Jeep Forum 1 09-14-2006 01:26 PM
Gladiator on the trail IOTJ Full Size Jeep Forum 3 09-14-2006 12:19 AM
68 gladiator transmission rama Full Size Jeep Forum 1 10-23-2001 03:55 PM
