gladiator floor pan repair - JeepForum.com
post #1 of 5 Old 10-09-2013, 09:26 PM Thread Starter
timwiller
1966 FSJ Gladiator
has anyone used aluminum and pop rivets for a fix? part of what i cleaned out forward of the passenger seat was AL. biggest issue is the seat mounting. i don't weld and can't afford hiring a body with eqpt. to do steel. i call it "dark rainy night in the jungle wrenching"??? a small portion of the tunnel is is gone on the passenger side. {drivers side is a street sign}
timwiller is offline
post #2 of 5 Old 10-09-2013, 10:42 PM
pleontks
1976 J-Series Truck
hit it up. street signs are free
Beauty is in the eye of the jeepowner.
pleontks is offline
post #3 of 5 Old 10-18-2013, 09:40 PM
0125JeepGuy
i'd use sheet metal screws rather than pip rivets, sheet metal screws dont have a chance of getting loose and vibrating around like pio rivets
0125JeepGuy is offline
post #4 of 5 Old 10-21-2013, 01:20 PM
usererror
1989 FSJ Wagoneer
I'm in the same boat with my 89. I'm noticing portions of the floor that are falling off under the carpet. I knew I would have to address it sooner or later.
Did you remove your carpet and then install your 'street sign aluminium' ?
usererror is offline
post #5 of 5 Old 10-23-2013, 12:44 AM
localfiend
Welder's really aren't that expensive. If money's that tight, could you borrow one from somebody? Might as well do it right. I had pretty much no body work or sheet metal experience and was able to replace a bunch of the floors in mine.
The Gladiators are heavy duty, get your self some 16 gauge, a hammer, and go to town. Easy to weld on stuff that's that thick.
2001 TJ 60th Anniversary Edition
1995 ZJ 4.0 w/ AW4 Swap
1966 Gladiator Pickup
1964 Gladiator Thriftside
localfiend is offline
