Full-Size Jeep Axle Identification! - Page 2 - JeepForum.com
post #16 of 58 Old 02-17-2010, 09:56 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Originally Posted by The_TwStD_1 View Post
Ok, after looking through this thread, I know that the Jeep I'm getting is an 8 lug with a HD d44 in the front, and an offset d60 in the rear, but what I don't know is this: What would the spline count be on those axles, and are lockers for a D44 universal for d44's and the same for the d60 provided the spline count matches up?
Jeep trucks didn't use the D44HD. People get this confused easily. Having an 8-lug pattern does not make a D44 a HD model. The HD's had distinct housing differences and were generally found in Fords. The 8-lug D44 in J-trucks is a regular LP D44 with 8-lug outers. Mr. N's page is a good reference for explaining this:
Mr.N's Dana Articles to Include 44, 60 information.
Jeep only used 30-spline D60FF's. The only 35-spline axe used in Jeeps was the 5x5.5" SF D60-2 from Gladiators.
The D44 front has 30-spline inners. 30-spline D44 carriers and (most, perhaps all) lockers are the same. They don't care if the axle is HP or LP. They are not compatible with anything D60 (which is why all the part numbers are different).
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #17 of 58 Old 02-17-2010, 10:04 AM
Angry_bald_guy
1985 J-Series Truck
Obviously, I don't expect a D44 locker to work in a D60, but what I was asking was, would any D44, 30 spline locker work in that front end, and would any D60, 30 spline locker work in that rear end or is it more application specific than that?
Darrel
A well regulated militia being necessary to the security of the free State, the right of the People to keep and bear arms shall not be infringed.
JFI Member #13
Angry_bald_guy is offline
post #18 of 58 Old 02-17-2010, 10:10 AM
PavementPounder
Cool as Ice...
No, that's basically how it works. I suppose there is a possibility that some manufacturers may do something different, but I think that the only "non-standard" things I have seen/heard of in some instances are some different bearing sets being required.
post #19 of 58 Old 02-17-2010, 11:24 AM
Angry_bald_guy
1985 J-Series Truck
Cool, thanks.
Darrel
JFI Member #13
post #20 of 58 Old 04-18-2010, 02:55 PM
81CJ8
1981 LJ Wrangler
Which axles were in trucks from 1963-1973? More specifically, the Gladiator.
81CJ8 is offline
post #21 of 58 Old 04-19-2010, 09:49 PM
PavementPounder
Cool as Ice...
http://www.ifsja.org/tech/figures/db.html
post #22 of 58 Old 10-01-2010, 01:48 AM
motorsports3
1997 XJ Cherokee
On the 84's GW how would you be able to tell if it has the Vac disconnect? Did all 85's have AMC 20's? Did some come with D44? Also did many of the fronts come with manual locking hubs?
motorsports3 is offline
post #23 of 58 Old 10-01-2010, 07:46 AM Thread Starter
BJ's Off-Road
1979 FSJ Cherokee
For the vac disconnect, there is a pod on the axle differential cover, it is obvious.
Every 1985 I have seen had an AMC 20 rear, I am pretty sure that most, if not all, had the 20.
The only front axles that had manual locking hubs are the Dana 20 rigs and the NP208 rigs.
Locking hubs are easily added though, just pull the drive flanges off and replace them with hubs.
www.bjsoffroad.com
BJ's Off-Road is offline
post #24 of 58 Old 10-01-2010, 11:23 AM
motorsports3
1997 XJ Cherokee
The AMC 20 is a large round rear end right? Because the Waggy im looking at is an 85 but seems to have a D44.
Here is a pic
Here is the front, it doesnt have vac disco
post #25 of 58 Old 03-24-2011, 08:18 PM
Osmosiz
1973 FSJ Wagoneer
im looking to buy a 65 wagoneer .. what axles are in that thing?
2000 XJ
will work for jeep parts
Osmosiz is offline
post #26 of 58 Old 03-25-2011, 10:59 AM
PavementPounder
Cool as Ice...
Use the link I posted in post #21.
post #27 of 58 Old 04-25-2011, 12:49 AM
jotter324
1976 FSJ Cherokee
good idea to convert front drums to disc. It's hella hard to find new drums
jotter324 is offline
post #28 of 58 Old 07-06-2011, 09:09 PM
CJ-Fan
Ok guys, I have never claimed to be a "Jeep Pro" but I feel like I know a whole lot about a lot of different Jeeps, GM, and old Ford (Mostly 66-77 Bronco) but I am stumped.... I picked up a rear D44 from a 88 G. Waggy. Everyone says all Waggy D44's are offset (at least a little bit) but this one is not.. flange to absolute CL of pinion is within 1/16" from either side... Another very confusing part of this, the wheel bearing, and seal assy... Every assy diagram I can find (All Data, ServiceNet, Mitchell, Haynes, etc.) shows an inner seal and an outer seal.. being that assembled - inner seal, bearing retainer, bearing, outer seal, then "guide plate" or "retainer flange", and then finally brake backing plate. There is, with 100% certainty, absolutely no place within the axle housing, that is machined to accept an inner seal? Anyone ever seen this? Any ideas if for some reason this is not the axle that should have been installed in this Jeep? Lastly, I know (personally, and very close) this Jeep was purchased and never messed with by the owner that I got this axle from...
CJ-Fan is offline
post #29 of 58 Old 07-07-2011, 05:56 AM Thread Starter
BJ's Off-Road
1979 FSJ Cherokee
I have seen some that didn't have an inner seal but I had never looked to see if there was a spot for it.
The way to figure this out 100% is to send me the BOM (Bill of Material) number on the axle and I'll tell you what it came from. Here is where to find the BOM:
www.bjsoffroad.com
post #30 of 58 Old 09-12-2011, 09:02 AM
xj95mj88
I just bought waggy 44's front and rear for 350. the person i got them off of doesnt know the year of the truck and before i start buying for the rebuild would the BOM number help identify the year? Its 610283-1. thanks for the help
xj95mj88 is offline
need info on full size jeep truck. tex62 Full Size Jeep Forum 0 02-21-2009 07:22 PM
full size jeep swap to cj? chris93263 Full Size Jeep Forum 0 01-24-2007 02:04 PM
Full Size Jeep Meet & Greet/Trail Ride 91G-Dub Full Size Jeep Forum 0 06-27-2005 05:36 PM
Full-Size Jeep Owners: Uwharrie Event in June!!! BJ's Off-Road Full Size Jeep Forum 0 04-15-2005 07:07 AM
Full size jeep P/U wanted glenzx Full Size Jeep Forum 2 02-02-2003 06:05 PM
