Fuel tank sending unit no ground wire? - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Fuel tank sending unit no ground wire?
ECGS Fall Sale - 10% Off EVERYTHING!!Gear Packages Available! Your # 1 Diff Shop is ROCKRIDGE 4ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 09-09-2014, 04:05 PM   #1
chris64
1979 FSJ Cherokee
Any help appreciated. Replaced sending unit, and still no results. Tank show dead empty. Does the sending unit need a ground wire? The original sender did not have a wire for ground either.
Thank you
C
chris64 is offline   Reply With Quote
Unread 09-09-2014, 10:12 PM   #2
CSP
It wouldn't hurt anything to add a wire from the sending unit to the frame to rule out the possibility one way or the other.
CSP is offline   Reply With Quote
Unread 09-11-2014, 07:41 PM   #3
cincyjeeprs
Might depend on the year. If you have a metal tank, it probably doesn't need one. My '90 has a platic tank and has a separate ground wire. I don't think that is the problem. Bad ground would peg the gauge. I think your problem is on the + side of the circuit. Open + wire or bad dash gauge, maybe?
cincyjeeprs is offline   Reply With Quote
Unread Today, 04:04 AM   #4
BagusJeep
BagusJeep's Avatar
1981 CJ7
You might have a poor ground path. The gauge reads empty at around 70 Ohm and full at around 15 Ohm. If you take off and short the sender wire for a couple of seconds you should see the gage rocket up.
If you have an open circuit you will see empty.
Two possibilities:
- poor ground - add a secondary ground from sensor to frame or preferbly to a black ground wire that is continuous to the back of the instrument cluster.
- duff sensor or one with the float full of petrol or sunk - best way to tell is to get a multimeter and measure the resistance at the sender.
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote
