Fuel Tank Problem - JeepForum.com
post #1 of 2 Old 04-19-2011, 09:53 AM Thread Starter
Swolford2009
1984 FSJ Wagoneer
Fuel Tank Problem
I have a 1984 Grand Wagoneer. I went to an electric fuel pump. The problem I am having is that when I fill the tank up I only can put a gallon or so in and then it overflows. I wait a few minutes and then I can put a little more in. I dont understand what the problem is. I am not using the return line and I have tried to plug it and leave it open with no change. I have the lines from the "carbon canister" open and that didnt help. Do I need to plug all the lines going to the tank and use a vented gas cap to solve this problem or something else. If anyone has switched to a electric fuel pump PLEASE tell me what you did with all your lines. I am a volunteer firefighter and I would like to use my Jeep to get to calls. I also have problems with it running out of fuel almost like it only uses a couple gallons and then can't use anymore. I had a 35ghp pump on it but I am replacing it with a 65-95gph pump. Any thoughts or tech advice would be appreciated!!!
Swolford2009 is offline
post #2 of 2 Old 04-19-2011, 10:48 AM
pleontks
1976 J-Series Truck
I run the elec fuel pump on both my 76 j10 and my 74 Gremlin.
There should be a tank vent line ran with your fill line. It should run from the tank to your filler neck, right inside the nozzle hole. I would check that, since it isn't filling. However, it being an FSJ, have you tried putting the fill nozzle in sideways? Neither my j10 nor especially the Gremlin will fill unless I put the nozzles in at funky angles. And I usually can't squeeze the nozzle handle very much, either. Also check the fill hose and make sure it is running downhill to your tank. I had to jerry-rig my fill hose with an exhaust 90, and I'd have to let it fill, then drain, then fill, then drain. So much better with the right piece now.
When I put the elec fuel pumps on, I remove all the vents (except the one to the filler neck) and charcoal canister, and add a locking vented gas cap. The vent lines from the sending unit, I just get a little piece of hose, and loop them back to each other.
When I get the opportunity (parts) I am going to reinstall charcoal canisters and run the vents. Guess I could use a coffe can, huh? Maybe new project for this weekend
I just saw a great diagram of the fuel tank venting, but can't find it now.
Kinda sounds like the running problem is a little bit of vapor lock, venting should take care of that.
Good luck.
Beauty is in the eye of the jeepowner.
pleontks is offline
fuel tank firegod33 Full Size Jeep Forum 0 10-13-2010 12:26 PM
fuel tank swap?? greenbeater Full Size Jeep Forum 5 12-03-2009 04:01 PM
81' J10 Step-side Fuel Tank abishop Full Size Jeep Forum 2 10-30-2009 07:33 PM
J300 in need of a fuel tank... TonyJ300 Full Size Jeep Forum 2 10-22-2006 07:48 PM
J10 Fuel Tank bhysjulien Full Size Jeep Forum 1 04-12-2004 08:34 AM
