Fuel Tank - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Fuel Tank
Winter & Offroad TiresIRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 08-28-2012, 10:20 AM   #1
WOLFMAN75
1989 FSJ Wagoneer
Fuel Tank
I need a fuel tank and skid plate for an 89 grand wagoneer, any suggestions on where to get one. about to pull my hair out, thanks
WOLFMAN75 is offline   Reply With Quote Quick reply to this message
Unread 08-28-2012, 02:36 PM   #2
Redseals
1990 FSJ Wagoneer
You can go to www.ifsja.org, www.bjsoffroad.com or www.teamgrandwagoneer.com. I had to buy a new skip plate for my 90GW from teamGW and it was about $500.00
Redseals is offline   Reply With Quote Quick reply to this message
Unread 10-08-2012, 12:49 AM   #3
mjcougler
2008 KK Liberty
Try these guys too:
http://www.mtscompany.com/index.htm
Mike Cougler
15 GC-L; 67 Jeep M725 ambulance;
04 Ram 2500 CTD; 46 Willys CJ2A (not running)
mjcougler is offline   Reply With Quote Quick reply to this message
Unread 10-08-2012, 08:07 AM   #4
BJ's Off-Road
1979 FSJ Cherokee
Originally Posted by mjcougler View Post
They don't have fuel tanks for the 80-91 rigs.
For the fuel tank you will have to find used, here are the rigs that interchange:
1980-1983 Cherokee
1980-1983 Wagoneer
1984-1991 Grand Wagoneer
www.bjsoffroad.com
BJ's Off-Road is offline   Reply With Quote Quick reply to this message
Unread 10-09-2012, 07:36 AM   #5
luckywagoneer
1989 FSJ Wagoneer
Im in the same boat with my 89 please let me know what the deal was and if you can post some pics and advise when you install for us thanks.
luckywagoneer is offline   Reply With Quote Quick reply to this message
Unread 10-09-2012, 08:15 AM   #6
SteelTherapy
1988 FSJ Wagoneer
I'm parting out my 1988 Grand Wagoneer.
Tank, Skid Plate and Sending Unit, $175. I'm not sure about shipping a used gas tank though...
http://www.greatlakes4x4.com/showthread.php?t=247108
SteelTherapy is offline   Reply With Quote Quick reply to this message
Unread 02-21-2014, 01:37 PM   #7
scottaa
1980-1983 Cherokee
1980-1983 Wagoneer
I'm looking for a gas tank for an 88 Grand Wagoneer...Are you saying a tank (new or used) from *any* of the above will fit, or I can only use 84-91 Grand Wagoneer?
scottaa is offline   Reply With Quote Quick reply to this message
Unread 02-23-2014, 09:56 PM   #8
BagusJeep
BagusJeep's Avatar
1981 CJ7
BJ were very helpful with my 1980 J20 tank but no one makes them. Not BJ's fault, that is just how it is.
It sufferred cracks but I found a cheap and simple method to weld up the cracks in the plastic tank. If that is your problem you may want to try and fix it rather than spend a lot of time and $$$ chasing second hand tanks.
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread 02-24-2014, 09:29 AM   #9
BJ's Off-Road
1979 FSJ Cherokee
Yes, all of those vehicles will have the same tank -- if it is stock which they 99% of the time are but there is always a chance a previous owner swapped something weird out.
www.bjsoffroad.com
Unread 12-24-2014, 07:27 PM   #10
brookedale09146
My 88 grand wagoner has two tanks; a long gas tank just forward of the rear wheels and a square metal tank just in front of the rear hitch. The fuel fills into the metal tank and than looks like it flows into the tank that is forward of the rear wheels. It looks like an auxiliary tank set up.
Was this how these came? My filler hoses are cracked and when I look to buy replacement hoses it only shows the set from the filler to the back tank and not the second set of hposes to the forward long tank.
a little help??
Thanks
brookedale09146 is offline   Reply With Quote Quick reply to this message
