fuel pump keeps dying/ need woodgrain templates
#1 | |
!elite FSJ amateur!
I've had to replace my mechanical fuel pump twice since February.
Are there any issues w/ OEM pumps that I am unaware of? Also, I am thinking of mounting an electric 'push' pump under-body near the tank to kill this mechanical pump issue once-and-for-all. Will it be necessary to take off the mechanical pump under the hood or can I just leave it there? Any help would be appreciated. Anyone know where I can get some templates for the faux wood graining on the body? Some friends and I want to make real wood siding. We've corrected the contouring issue, just need to get the proper sizing down. Since I do not want veneer, I might even miter/cut a 'hole' and place a wood piece within the fender/doors/quarters; then weld the seam shut. Yeah, I'm bored! cheers all!
"May you, with age, never sag more than your GrandWagoneer." |
#2 |
The pumps are dying from crud coming up the lines and getting caught in the inlet valve, or grinding up the diaphragm. I cure that by adding an inline filter (see thru) right before the pump.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
