Fuel leak 82 jeep wagoneer limited - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Fuel leak 82 jeep wagoneer limited
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIron Rock Offroad products - get them from Kolak!TERAFLEX JKU 2.5" Elite LCG Long FlexArm Lift Kit w/
Unread 04-13-2015, 04:23 PM   #1
82wagoneer
My jeep leaks fuel when I'm filling the fuel tank. Also I've been smelling fuel off and on while driving daily. Has anyone had thus problem and is the tank vent serviceable without removing the fuel tank? I'm working on a 82 jeep wagoneer big v8 4x4. Single fuel tank.
82wagoneer is offline   Reply With Quote Quick reply to this message
Unread 04-13-2015, 04:54 PM   #2
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
Inspect the filler tubes. If you have a cracked fill vent tube you will smell gas all the time. It's pretty easy to get too, just crawl under.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
RockRollin is online now   Reply With Quote Quick reply to this message
Unread 04-13-2015, 08:05 PM   #3
82wagoneer
I pulled the sender and I noticed that I have no gasket or o-ring under the sending unit. Does anybody know if i require this o-ring?
82 jeep wagoneer
Unread 04-13-2015, 09:37 PM   #4
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
There is a gasket on my 90, would guess the same for 82.
"I like fun" Edd
