Fuel Issue - JeepForum.com
post #1 of 10 Old 03-14-2011, 07:36 PM Thread Starter
Swolford2009
1984 FSJ Wagoneer
Fuel Issue
I have a 1984 Grand Wagoneer that has a 360. I just put an Edelbrock intake and carb on. I did away with all the emissions crap and disconnected the fuel return line. I am running a mech. fuel pump that runs 9psi. I decided to put a regulator on to get it around 5psi. I can't get fuel to the carb now and it is really getting frustrating. Sometimes I get too much fuel and then it goes the other way. Is the fuel system touchy on these Wagoneers? This is my first time messing with a Jeep/AMC. I am a Chevy guy. If it was a Chevy I would have it figured out by now. Any help would be appreciated!
Swolford2009 is offline
post #2 of 10 Old 03-14-2011, 08:03 PM
pleontks
1976 J-Series Truck
Get a vented gas cap. Or try running it in the driveway with no gas cap. I'm assuming that the charcoal canister went along the way with the emmissions crap?
I like to run the electric fuel pumps.
pleontks is offline
post #3 of 10 Old 03-14-2011, 08:40 PM Thread Starter
Swolford2009
1984 FSJ Wagoneer
I still have to canister but only two lines are still hooked to it that run down behind the motor and go?????? I will try the gas cap and see what happens.
post #4 of 10 Old 03-15-2011, 12:42 AM
pleontks
1976 J-Series Truck
Didn't notice fuel filter on the list........
Maybe crawl under and check that you didn't miss one.
Could be that the pickup sock in the tank is clogged. Trying blowing into the tank through the gas line and have someone listen to hear if it bubbles. I blew out all my hard lines with the compressor, and replaced all the rubber.
My last truck was a 84 chevy 3/4 ton 2wd 350, I traded for my j10, and then did everything I just did to the chevy to the j10. Got rid of the motorcrap carb and put on my qjet Other than the carb and the return line from the filter, the fuel system's pretty much the same as the chevys.
The two hoses off the canister should go back to the vent on the tank. Both hoses. 'Should' be another to the carb....
Good Luck
pleontks is offline
post #5 of 10 Old 03-15-2011, 10:39 AM Thread Starter
Swolford2009
1984 FSJ Wagoneer
Went out and pulled of the gas cap and still same result. It seems like it has a hell of a time getting gas up to the carb. It does have a new fuel pump. I have two aftermarket fuel filters up by the engine but didnt see any underneath the jeep. Maybe I didnt see it but it did have a stock filter up on top with a return outlet on it. Something is messed up with the fuel system because it did this when everything was still stock. The fuel would drain back out of the line and have a hard time getting it back up to the carb. The way I have it set up right now is the same way I have always done it with V8's I have had in the past with no problem. The Jeep has set for over 10 years in a garage if that makes a difference on troubleshooting. Again I appreciate any help I can get!
post #6 of 10 Old 03-15-2011, 10:54 AM
pleontks
1976 J-Series Truck
My chevy would do the drain back real bad, as well as my Gremlin. That's what I like about the electric fuel pump - it self primes. When I start em up, I just let the fuel pump pump for a couple seconds before kicking the engine over.
Hopefully I've been some help, but that's about all I've got
pleontks is offline
post #7 of 10 Old 03-15-2011, 12:52 PM Thread Starter
Swolford2009
1984 FSJ Wagoneer
I am really starting to like the electric fuel pump idea!!
post #8 of 10 Old 03-15-2011, 03:42 PM
pleontks
1976 J-Series Truck
It took a while for me to get convinced, but I automatically run it on everything now.
Make sure you put it as close to the tank as possible, and pointing up. Grab a 3/8 or 5/16 barb nipple for the supply end for when you change out the one that came with it.
Pair it with a clear filter in the hood, and you can also see if you got gas or not.
pleontks is offline
post #9 of 10 Old 03-15-2011, 03:49 PM Thread Starter
Swolford2009
1984 FSJ Wagoneer
I know this is kinda off topic but is there any important info I need to know about this 360 and or the Grand Wagoneer itself? I don't want to be caught off guard about anything on it.
post #10 of 10 Old 03-15-2011, 06:55 PM
pleontks
1976 J-Series Truck
Not too much. Mine's a bit older but......
Keep an ear on the two rear main bearings. They tend to go out first.
The wiring sometimes catches fire.
After the emissions comes out, the only real differences between the years are the tranny/tcase combo, and the wiring. At some point they switched to the plastic dash, but even that, I'm sure, can be switched out with the older metal one.
Lots of ford parts that need to be replaced with non-ford parts
pleontks is offline
1986 Wagoneer Fuel Delivery Issue BonesMachine Full Size Jeep Forum 8 10-18-2010 04:24 AM
Gladiator fuel delivery problem, not getting fuel gladman Full Size Jeep Forum 5 02-10-2010 11:09 AM
new fuel pump, no fuel... 44BZ Full Size Jeep Forum 4 11-28-2009 09:33 PM
WTB - Fuel Filler Hose and Fuel Vent Hose, 81 J10 Sportside DonC Full Size Jeep Forum 3 04-26-2009 08:31 PM
Fuel Starvation Issue after Conversion to EFI 1975Waggy Full Size Jeep Forum 4 04-13-2009 12:21 PM
