Fuel Injection and PCM - JeepForum.com
post #1 of 8 Old 09-29-2013, 10:29 AM Thread Starter
Uechi
Hi everyone
I am in the process of deciding exactly what I want in Jeep Wagoneer. Two things I do not want are fuel injection or a PCM/Computer. It is my understanding that Jeep never put fuel injection in the Wagoneer ( 1963-1991). Is that correct? The other issue is a PCM/Computer. Can someone alot more knowledgeable then me tell me what year Jeep started putting PCMs in their wagoneers? With that information I can narrow down my search for a Jeep. Thanks in advance.
Uechi is offline
post #2 of 8 Old 09-29-2013, 05:13 PM
RockRollin
1990 FSJ Wagoneer
No EFI, no computer anything.
Does have electronic ignition with a control module (post 73), but that's it, and if that's a concern, many guys carry a backup module with them.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #3 of 8 Old 09-30-2013, 12:11 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Yep, 74 and up will be running an ignition module. Carry a spare if you're worried.
Pre 74 will be points style ignition.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #4 of 8 Old 09-30-2013, 04:05 PM
jeeper54
Yep, all old school with carburator adjustments, manually set timing, etc.
jeeper54 is offline
post #5 of 8 Old 10-10-2013, 01:00 PM
super98lsc
and Ouija board for navigation.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #6 of 8 Old 10-11-2013, 08:12 AM
TUDrewser
1990 FSJ Wagoneer
Not entirely true...I believe Cruise Control is run by a computer, at least in the late models. My '90 has a yellow box under the dash for it. But you can always disconnect it if you really want no computer
TUDrewser is offline
post #7 of 8 Old 10-13-2013, 11:29 PM
jeeper54
Not really a computer, as such, but more a module similar to what's found in the ignition system. Leaves only you to troubleshoot/adjust if the engine isn't running right.
jeeper54 is offline
post #8 of 8 Old 10-21-2013, 11:27 PM
carnuck
1984 J-Series Truck
The 4.2L has a computer for the BBD carb. Turn key to on (not start) and unplug it, then do Nutter Bypass or HEI dist to fix the timing.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
