Frozen Engine - Page 2 - JeepForum.com
post #16 of 34 Old 01-26-2013, 02:55 PM
1983Chief
I bet the block is busted either under the intake or the outside beside a freeze plug. I work on car and boats with my dad all year and 99% of the boats that come in and haven't been winterized will have some freeze plugs left in the block and it'll crack the side out. Sometimes even when the plugs have come out, it'll still freeze and that's at lows around the 20s. And x2 on what 73 fsj wagoneer said, watch for white smoke and milky oil.
1983Chief is offline
post #17 of 34 Old 01-26-2013, 03:19 PM
jeepdj5
1982 FSJ Cherokee
Can you get your hands on a kerosene shop heater? If it gets cold again it will crack if it has not already! When I was little I put water in a foam coffee cup and each week I would check it and it would be bigger each time till the cup broke! Even after its already solid ice it keeps getting bigger and bigger! I would heat it up soon for better luck! Or also maybe a small camp stove under the engine? YOU NEED TO HEAT IT UP!
Sent from my fsj Cherokee chief using JeepForum
jeepdj5 is offline
post #18 of 34 Old 01-26-2013, 03:20 PM
jeepdj5
1982 FSJ Cherokee
Oh ha ha the coffee cup was in the shop freezer, I went there once a week
jeepdj5 is offline
post #19 of 34 Old 01-26-2013, 03:29 PM Thread Starter
Eric_B_1984
1987 FSJ Wagoneer
I don't think I can get my hands on one by the time the weather breaks anyway. I hate to sound like this, but I do have a Centerbolt 350 sitting here with a stand alone throttlebody injection kit on it. If this engine is toast, I will just call up transdapt and put the Chevy in it. I am a diesel man myself tho, I would much prefer to put a 6.6 LBZ Duramax in it, but what I have is what I have. But honestly I have put that engine through hell and back, she's a trooper, I think she'll pull through this one.
Eric_B_1984 is offline
post #20 of 34 Old 01-26-2013, 04:04 PM
pleontks
1976 J-Series Truck
I froze mine. Thawed it out with heater underneath. Everything was fine.
Just so someone is giving you a 'best' case scenario instead of worst
Beauty is in the eye of the jeepowner.
pleontks is offline
post #21 of 34 Old 01-26-2013, 05:44 PM
TrboDslWagoneer
1973 FSJ Wagoneer
I love the D-Max. Would make an awesome swap with an Edge 2 programmer.
1973 wagoneer
6.2L Detroit diesel with 6.5L Turbo heads and Turbo
700R4 transmission it 4L60E upgrades
4" straight pipe
TrboDslWagoneer is offline
post #22 of 34 Old 01-26-2013, 07:38 PM
RockRollin
1990 FSJ Wagoneer
X2 it will be fine. I have thawed more than one in my lifetime. Once the waterpump moves just go slow as prescribe d in earlier post.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #23 of 34 Old 01-26-2013, 09:50 PM
jeepdj5
1982 FSJ Cherokee
I would heat it up, you should go buy a camping stove from Walmart and thaw it out
jeepdj5 is offline
post #24 of 34 Old 01-27-2013, 03:20 AM Thread Starter
Eric_B_1984
1987 FSJ Wagoneer
I don't have the money at this juncture to be buying anything like that right now. Like I've said I've put her through far worse. I know she'll pull through. The main point was, when I realized what happened I felt so stupid that I wanted to know that I was not alone.
post #25 of 34 Old 01-29-2013, 06:34 PM
jeepdj5
1982 FSJ Cherokee
Still frozen?
jeepdj5 is offline
post #26 of 34 Old 01-29-2013, 06:42 PM Thread Starter
Eric_B_1984
1987 FSJ Wagoneer
No she's free. I won't be able to run it enough to see of there is any permanent damage until Thursday thanks to my schedule. We are supposed to get all kinds of rain tomorrow
post #27 of 34 Old 01-31-2013, 08:34 AM
jeepdj5
1982 FSJ Cherokee
Good rain means above freezing
jeepdj5 is offline
post #28 of 34 Old 01-31-2013, 10:24 PM Thread Starter
Eric_B_1984
1987 FSJ Wagoneer
Welp, I will consider myself boned until I can borrow a lift. I poured a gallon of antifreeze in her, everything seemed fine, so I walked back to the house to fill the jug with water, came back to find the antifreeze GUSHING from somewhere between the engine and trans in that area. I didn't bother crawling under it, I just did the AMC walk of shame back to my apartment and moped for a while.
post #29 of 34 Old 01-31-2013, 10:39 PM
jeepdj5
1982 FSJ Cherokee
There are freeze plugs back there
jeepdj5 is offline
post #30 of 34 Old 02-01-2013, 02:51 AM
RockRollin
1990 FSJ Wagoneer
That sucks! Lucky enough for it to be the heater core return line?
"I like fun" Edd
