Front End Noise - JeepForum.com
post #1 of 3 Old 02-21-2004, 10:50 PM Thread Starter
orangetang
orangetang's Avatar
Front End Noise
Jeep Model: 86' Wagoneer 2.5L I4
Problem: When I engage 4L or 4H, the front end makes a terrible sound when the vehicle is in motion.
The sound is similar to a very tight winch cable jumping on the drum. A 'snap 'snap, like a bike chain jumping gears under high load. The jeep itself is very noisy, so it's hard to pinpoint the sound. I suspected the T-case to be the problem, but the manual says it woudl be the front diff, or axle (front diff is where it sounds like the problem is).
I took off the diff cover to inspect any wear/problems. The oil was clean, green and contained no filings or signs of wear. I spun the front DS and watched for any missing teeth or obvious problems. Defeated, I replaced the gasket/fluids and don't know what else to do. Any suggestions?
Here are some links to pictures I took of the front Diff.
Oh, and if someone can tell me what Tcase I have. I believe it to be an NP231, but I'm unsure. My front driveshaft connects to the Tcase with a CV joint, not a Ujoint. Any ideas? I'll post an image of it aswell.
Diff Pics
www.screenlooking.com/images/jeep/dscf1020.jpg
www.screenlooking.com/images/jeep/dscf1021.jpg
www.screenlooking.com/images/jeep/dscf1022.jpg
www.screenlooking.com/images/jeep/dscf1024.jpg
www.screenlooking.com/images/jeep/dscf1032.jpg
TCase Pics
www.screenlooking.com/images/jeep/dscf1035.jpg
www.screenlooking.com/images/jeep/dscf1038.jpg
www.screenlooking.com/images/jeep/dscf1042.jpg
orangetang is offline
post #2 of 3 Old 02-22-2004, 12:08 AM
Silver yj
I would check the U-joints in the front drive shaft sence it only does it when its in 4x4 also check out by the front hubs for the noise.
Silver yj is offline
post #3 of 3 Old 02-22-2004, 04:57 AM Thread Starter
orangetang
orangetang's Avatar
Thanks, I'll check that out next.
Any idea on what transfer case this is?
Chirping Noise When I Rev Gas regmason2 Full Size Jeep Forum 5 02-16-2010 07:39 PM
noise and vibration davoo Full Size Jeep Forum 1 11-15-2008 04:57 AM
front diff noise or is it? jjsticks Full Size Jeep Forum 1 02-15-2008 08:38 AM
Front Wheel Noise after Upsizing Tires GlobeTrekker Full Size Jeep Forum 1 11-02-2005 07:11 PM
Ticking Noise Woody89 Full Size Jeep Forum 2 09-17-2003 02:06 PM
