Front Dana 44 closed knuckle DRUM to DISC conversion - JeepForum.com
post #1 of 3 Old 06-07-2007, 10:40 PM Thread Starter
farinspace
Ok im going to attempt a front D44 drum to disc conversion, but i need a little help ... ive been doing a little bit of research and think i can pull it off. I was given the following site for reference:
http://earlycj5.com/tech/brakes/disk...conversion.php
which is for a CJ but info is still relevant and that site referred me to:
http://completeoffroad.com/wsm/i-437...0_dana_28.html
http://completeoffroad.com/wsm/i-730...on_blazer.html
I checked out my local junkyard and came across chevy k10 4x4 with which appears to be a dana 44 up front ... here are the pics, if anyone can confirm my finds i would appreciate that:
What i want to know is if anyone here has done it before? and if so what advice do you have? Or if anyone has additional resources Id appreciate it very much ... I plan on writing a write-up when the fat-lady-sings ...
The part that im still a little unsure about is dealing with the master cylinder, currently the J2000 has a vacuum booster for additional vacuum for the brakes, does this mean that the current master cylinder is NOT a hydraulic system? And if that is the case I assume i would also need a hydraulic master cylinder, would i have to replace the big tank behind it as well?
As you can figure out im a little unclear about this part of the install, so if anyone has addtional resources here please let me know.
Im mechanically inclined and am the type of person who believes anything can be done, and that things arent as hard as they appear. I havent been working on cars/trucks much so any additional advice is also welcome.
98 TJ, 4.0L I6, 5sp, 4.88 Alloy Gears, D30[Aussie Locker]/D44[Detroit TrueTrac]
33" Toyo Open Country MT, 2" BB Lift + 1" Eng./Body Lift, TW SYE + Drive Shaft
farinspace is offline
post #2 of 3 Old 06-11-2007, 08:59 PM
ROWA
ROWA's Avatar
farinspace,
The brake vacuum booster is like power steering for your brakes. The vacuum from the intake manifold acts on the diaphragms surface area to increase pressure in your master cylinder in addition of the pressure from your brake pedal.
The problem with a conversion from drum to disc is that disc brakes require more fluid volume than a drum system. You will need to replace the master cylinder and the brake proportioning valve. A GM master cylinder for disc/drum brakes should work.
Good luck,
ROWA is offline
post #3 of 3 Old 07-11-2007, 07:48 PM
ronprice
ronprice's Avatar
Ive done it on scout 44 closed and it was a sinch. Had to make some home made caliper mounts besides that its all bolt on. Should be the same I would think.
Family of 5<Myself and 4 girls. Out numbered and dont care that I leave the seat UP.
-OIIIIIO-
ronprice is offline
1973 waggoneer drum to disc qeustion mokthraka Full Size Jeep Forum 5 09-08-2009 09:46 AM
Rear disc brake conversion for GW D44? RockRodHooligan Full Size Jeep Forum 4 04-19-2009 08:59 PM
J10 Disc Brake Conversion/ Tran swap gerard_j Full Size Jeep Forum 2 03-02-2009 10:27 PM
Axle swap 77FS w/disc into 73FS w/drum JYDToo Full Size Jeep Forum 6 01-25-2009 12:02 AM
rear disc conversion? shakari Full Size Jeep Forum 6 06-18-2004 09:35 PM
