Front belt drive pic request - JeepForum.com
post #1 of 3 Old 03-08-2011, 04:27 PM Thread Starter
Fixxxer_ZJ
I'm putting the new motor in my 80 cherokee, 360 ps and ac. I was wondering where the triangular bracket with four bolt holes in it goes...
Thanks
1998 5.9 Limited, CAI and Exhaust-My toy
2002 WJ Limited 4.7 HO, QuadraDrive-also mine :D
Fixxxer_ZJ is offline
post #2 of 3 Old 03-23-2011, 08:58 PM
jdschlaud
dont have any pics. but if you hold the brkt with long side facing down that bottom hole goes down on the oil filter/ pump hsg. next hole up on right side goes through timing cover bolt. about 2 in up from that the 3rd hole matches up with a bolt running through the water pump. and last bolt on left side bolts to cast alum AC pump brkt.
i hope this helps. did some looking here
http://www.ifsja.org/forums/vb/showthread.php?t=137218
its just missing the cast alum AC brackt that goes behind the steel brkts
jdschlaud is offline
post #3 of 3 Old 04-05-2011, 11:08 AM Thread Starter
Fixxxer_ZJ
Thanks, got her figured out now.
pic request- 360 A/C alt brackets & spacers CutterN55 Full Size Jeep Forum 1 06-02-2010 12:17 PM
89 Grand Wagoneer front drive shaft Tfastlane Full Size Jeep Forum 2 02-09-2009 06:50 PM
New To Forun Drive Belt Problem WHIZZ Full Size Jeep Forum 1 08-27-2006 09:55 AM
Compatible front drive shaft for 79 J10? migliori Full Size Jeep Forum 1 09-09-2005 03:44 PM
Belt Change? Mr98Pontiac Full Size Jeep Forum 3 11-04-2002 11:22 AM
