frame warpage or motor mounts ? - JeepForum.com
post #1 of 4 Old 12-03-2009, 03:51 PM Thread Starter
riotstarter
1976 J-Series Truck
hi i got a 76 j10 with a il6 4.2 258 and the truck seems to be sluffing on the front drivers side pretty bad i mean i measured bothe sides driver and passenger side and the drivers side seems to be 2 inches shorter, i checked the mounts and the drivers side was waaay down and passenger was way up.
I also looked underneath where theres those rubber blocks on the frame on both side and it seems like the drivers side frame is higher up compared to the passenger side which was lower to the axle.
riotstarter is offline
post #2 of 4 Old 12-04-2009, 09:52 AM
greenbeater
greenbeater's Avatar
1968 FSJ Wagoneer
springs sagging a bit?? could be a good reason to lift it a little
his - 68' Wagoneer, 455 Pontiac, tons
hers - 00' XJ tail rig D44, C9.25, 4.56
ours - 01' WJ 4.0
greenbeater is offline
post #3 of 4 Old 12-05-2009, 11:46 PM
carnuck
1984 J-Series Truck
Is the motor leaning?
carnuck is offline
post #4 of 4 Old 12-08-2009, 09:04 PM Thread Starter
riotstarter
1976 J-Series Truck
its not leaning at all actually that was one thing i just checked and it seemed to be level and straight.
J10 frame building Ennui_Bliss Full Size Jeep Forum 6 12-13-2009 01:31 PM
49 willys frame WvWillys Full Size Jeep Forum 2 08-03-2009 06:38 PM
79 J10 Transfer case, motor mounts broke j10driver Full Size Jeep Forum 2 10-26-2008 01:44 AM
Wiily Pickup frame swap for Jeep frame. mikeymule Full Size Jeep Forum 4 05-28-2008 03:18 PM
need info on snow plow mounts 1976cherokee Full Size Jeep Forum 0 12-06-2003 03:04 PM
